Yeah I understand that
I will be running 50/50 with the tune.
Everyone can drive off boost so even of I run out its not the end of the world you can still drive around off boost right? Just not thrash it
If you did that you would have to be extremely careful not to ever come onto boost if you had really ramped up the boost / timing with the WM mixture injecting. Otherwise good bye motor very very quickly! I wouldn't feel comfortable driving it around like that for any period of time!
Just get a float sensor for the tank and a warning light, and carry some extra WM with you. Or invest in a failsafe device.
I recently bought the AEM failsafe device which looks very good. I will use it to trigger a second map in the ECU.
Hes got a float sensor/warning light already yeah.
I would aim to have it tuned with 2 stages of boost, where the low boost is perfectly fine without the WMI and the high boost is WMI dependant.
Best of both worlds :thumbsup:
Maybe get a fail safe and wire it up so that it will kill the power/remove the ground to your boost controller when it's triggered. That way if you run out it'll just run off gate pressure which is better than nothing...
Pretty sure snow make a safe injection/fail safe type thing, but most brands will probably work with your kit.
Edited by Mitcho_7
  • 1 month later...
Im going to try install a air/water atomiser inbetween the turbo and airflow meter and see if it works. Get rid of the pump
system. Don't know anyone thats tried it so will be suck and see, to see if the air upsets anything...
cheers
darren
Compressor wheel erosion will occur.
Errr, i know you know a lot...but your wrong this time, very wrong ..done it heaps of times...only air sprays wear out wheels..air/atomisers do not
the air side of breaks the water down into much more fine microns than shitty arse chinese bilge pump setup...lol. My coolingmist
kit even with there new fange dangled super atomiser is no where near as fine as my air/water atomiser....
I have done this, more than once... so i speak from experience, i didn't read about it on the net inbetween masturbating
on redtube..lmao
cheers
darren
Edited by jet_r31
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
