A few pics of my stagea from the UK
SPEC
Was an RS Four originally
Engine is early 32 N1 block
Forged Tomei internals
Trust oil; pump
N1 water pump
Tomei cams
ACL bearings
AP head bolts
Garrett 2860-5s HKS turbo elbows
HKS F con V pro Gold with launch control
profec b boost control with steering wheel boost switch
Tomei fuel pump on seperate cicuit
Exedy riple plate carbon clutch
RS Four S twin synco gearbox
LSD
Greddy induction
HKS intercooler , radiator and oil coler
Electronic Accusump
Nismo engine mounts
Custom 80mm stainless exhaust
HKS downpipes
Suspension is series 2 Nismo S tune
GTR hubs ( to take fork suspension)
Nismo rear lower camber arm
Adjustable rear arms (cusco)
Whiteline ARBs and bushes
Front & rear strur braces
Ap Racing brakes 343mm front
34GTR V spec brakes rear
Nismo bodykit
Ultralite nurenberg wheels with 245 40 18 topyo 888s
recaro seats with retrim to match.
apexi el II gauges
batterey relocated to rear wing
Carbon cooling panel. facia & plenum cover.
Series 2 rear lights
i wont make any power or performance claims as it seems to upset people
I will just say that it is on maximum torque by 4500rpm and it is quick enough for me.
https://www.sau.com.au/forums/topic/396707-my-stagea/
Nice- I'm liking-
The NA (I think) grille
The strut brace- its a nismo right or Kansai?
The cleanness of the engine bay!
Whats that do-dah on the steering wheel? To many Danger to manifold jokes to be had there...
Whats the little plaque on the cam cover say?
Don't worry about the performance claims- Dynos are all completely different- and ramps rates, gears, operators etc etc all end up to be too many variables. Take it to the track- practice (said it was the first time yeah?) and lay down some numbers. Then you'll know where you stand! At the end of the day- if it puts a smile on your face- then happy times.
Good to have you here.
https://www.sau.com.au/forums/topic/396707-my-stagea/#findComment-6300404
Yes it was .
I had to re register as changed email address and the password stopped working. This is where it is at now
The grille is the an NA one but it is also the one that goes with the nismo bodykit
The front strut brace is Kansai , rear is custom.
The button on the steering wheel is a remote boost switch that changes from low to high or of course the other way.
With this i can drive around on low and switch to high (1.5bar) immeadiately without taking my hands off the steering wheel.
The plaque
It is in memeory of Rob Gallager aka Tweenierob the guy and (mate) that built and mapped the engine .He was one of the top UK mappers and died in a road accident aged only 31
Edited by Greanmachine UK
https://www.sau.com.au/forums/topic/396707-my-stagea/#findComment-6300575
Why would anyone get upset with your power or performance figures?
There was some misunderstanding in the Stagea performance thread. I couldn't follow all of the ranting.
BTW, nice ride. Cars like yours would be a rare sight on the roads around your home town I'd imagine.
https://www.sau.com.au/forums/topic/396707-my-stagea/#findComment-6300689
Looks great, feel free to share preformance figures, ignore the crap some people carry on with and as Alex said, as long as you enjoy it.
Have you got some more photos of the seats and dash. Curious to see what you have done as I have been thinking about similar mods. I'd like to switch seats but only if they matchs the trim, same goes for dials etc.
https://www.sau.com.au/forums/topic/396707-my-stagea/#findComment-6306793
a dyno print out
Max power 502.9 max torque 455 ft lbs. at the hubs
For reference the figures are the ones I have . They are awd at the hubs on dynapack rollers at Abbey Motorsport who are not known for silly claims. However please feel free to convert to downunder figures in any way you choose - Im not going to .
Personally I only use they as a comparison between then and now or in the future, they are what they are.
It has had a few mods since then . Power is down a small bit but the torque is up to around 480
And thanks for your concern wolverine the amps is bolted down
https://www.sau.com.au/forums/topic/396707-my-stagea/#findComment-6310597
I hope the new format of the forums doesn't start causing issues for you (and others) again like the old one did...
I had lots of problems with the old format but then Prank fixed it with what he called a band-aid solution. The one thing that still bugged me was that if you clicked on a link when you tried to close the link it would close SAU instead - that appears to be fixed now with this latest version.
https://www.sau.com.au/forums/topic/396707-my-stagea/#findComment-6311227
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
