14 minutes ago, Piggaz said:
Well, guys get all excited about a billet wheel being lighter.... but most of the weight is in the turbine wheel. The efr wheel is half the weight of a normal inconel wheel.
Removal of all the small piping and super tight bends of the intake and exhaust. Just look at it all, it's hardly designed for MASS airflow. Put a pressure sensor on the intake of a 450 kw gtr and I bet it's pulling bulk vacuum. Dyson would be impressed.
Haha, Piglets rebuild of his busted Dyson :D
34 minutes ago, ActionDan said:
I wonder why BMW went with all the hassle of twins on a straight 6 motor instead of a slightly larger single?
I guess they wanted to make it laggier. I mean, 1400 rpm is pretty shit response - A single would be on idle for sure.
I bet a cheeseburger that their packaging is not a spitting image of the RB26 configuration.  A huge amount of my argument against low mount twins in a GTR when any kind of flow is needed has to do with the packaging.
Edited by Lithium
Yep 100% you can't get a bigger exhaust housing on to those stock manifolds and the rear intake in rubbish.
Would like to see some low mounted EFR's on customer manifolds.
"When any kind of flow is needed" means different things to different people.
I think you guys need to go back and read some of your own posts from 10yrs ago on here and see how you were reacting to 300-350rwkw back in the day.
For those power levels, even today, twins are fine for a mildly driven street car. Does that mean there are not better solutions? Of course not, it's been a decade of tech advancement, but the argument seems to boil down to "did you know that if you spend more time and money you will get a better result?!".
No shit lol
Edited by ActionDan
  • Like 1
Artec do a 0.85 T28 ass.
4 hours ago, Lithium said:
9180 would do for now :D
Hows that build of yours going?
Sick f**king work Piggy, looking forward to seeing the final result - but you're already smashing it. Can't wait for the data, and for you to finally be able to get out there and do awesome shit with it.  I remember the OTP discussion we had back in 2013 where you were challenging me to think of any RB setup with response and power like your own, bet you wouldn't have expected your own car to end up with a single turbo on the exact same engine and as a result stand up harder earlier than it ever did before? :D
f**king kudos to having the Insight involved to get a great thing even better.
Honorary mention gotta go to the drunken conversations with the Wild the sphincter of the universe Rare Breed.
* This post sponsored by the SAU language filter
Slowly getting there. Wiring was completed last week so a little more fab then it can get some fluids and a tune :)
  • Like 1
I'm curious what spark plug gaps you are running with the Godzilla motorsport kit?
I might need new coilpacks and was thinking this kit over the conventional splitfires.
In the search your the only guy i saw that runs the Godzilla R35 billet coil pack kit, so curious on your opinion on why you went these over spitfires.
I'll have to get back to you on that. Some plug that Scott uses. It's a heat range 9 with a funny tip. I thought I took a photo but I can't find it.
Actually i just saw this in a comments Facebook section of the Godzilla Motorsport page which to me was interesting.
So i spose its just for cars to run high power reliably without a breakdown in spark. Rather than what i thought of larger gap better bang/performance
Bruce Sullivan What plug gap can you run with these ? Can you get away with 1.1 for around the 450AWKW's ?
Cheers
LikeShow more reactions
 · Reply · May 28, 2016 at 7:43pm
Remove
Godzilla Motorsport
Godzilla Motorsport No turbo engine should ever run 1.1mm gap . That is only for na engines
 · Reply · May 30, 2016 at 5:52pm
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
