Hi guys
I am finally comfortable taking my car to the track after getting some perishable bits replaced.
But before I do so I want to put in a oil cooler. Now I don't want to spend more than $500.
That basically eliminates all the jap brands.
Are there any recommendations from you guys for a oil cooler with a thermostat that has been put through its pases?
I have found the driftworks one, trying to stay clear from eBay specials.
Thoughts queries?
Link of oil cooler in interested in.
http://www.shop.cartel-aus.com/Thermostatic-Basic-Oil-Cooler-Kit-DWEB016.htm
Thanks
https://www.sau.com.au/forums/topic/397932-need-a-hand-choosing-a-oil-cooler/
  • Replies 57
Would rather not put a second hand oil cooler in. Can flush it put to a extent but you never know what's in there.
Running a second hand trust oil cooler and relocator kit i bought off a fellow SAUer on mine, flushed out and cleaned before use and is a fantastic bit of kit
With proper cleaning and flushing any kit will be brand new just need to take the time to do it properly
I believe I saw a HKS kit in the forsale section
Still too much of a scaredy to cat to go second hand on a oil cooler. To me it feels like buying a second hand oil filter haha.
Mocal is a good brand - looks like a well priced kit - new is safer.
Thats good to know. Might actually stick to my original.
Have you looked at DIY'ing a kit? Greenline can source genuine greddy thermostats/take off plates for ~$200, leaves you with $300 for a core and two lines.......
No I have not considered this. If I dont get a kit then I might aswell experiment with a DIY kit.
There has been a group buy of a UK brand kit (can't remember the company) that was in your price range.
Indeed there has, HEL was their name, braided lines are their game. (couldnt resist)
Setrab make great coolers, check them out.
Will have to look at this as well.
Go for the mocal one driftworks sell ,good vaule for money.
Are you running one?
Thanks for the help so far guys. Much appreciated. Keep em coming :thumbsup:
Edited by eat_me
You guys think for a 2,3 time a year track warrior like myself requires a 19row core? Seems a bit extreme to me, but maybe seeing as its thermo it doesnt matter, just means when things get hot the cooling will be better due to larger surface area? correct? Or should I go for a 10, 13 row.
install an oil temp guage, are oil temps going over 120-130c? if yes, install an oil cooler, if they are still going over that you should have installed a larger one.
I have never had the car on a track. As for drags and hill driving (mucking around) I have not seen those temps rise that high.
This is basically just a precaution prior to going to the track. Wise decision? Or am I being silly?
I would hit the track first, with an oil temp gauge which I'm assuming you have. If you see your temps getting that high, take it easier and make plans to get an oil cooler. Chances are you won't see them get that high on your first time out anyway, unless you go on a hot day. Until you actually need an oil cooler, it's just another thing that may go wrong and cause problems.
http://www.helcarkits.co.uk/index.php?main_page=product_info&cPath=205&products_id=903
I'm recieving this in mail soon postage was 10 pounds so 250 pounds all up not to sure how conversion is atm.
They have 10 row up to 19 row kits all awesome quality remember another member referred me to the website and he's been very happy with his kit. There is a 19 row kit specifically for the skylines/silvias but if you mention the car it is for they will supply the correct sandwich plate
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
