shit just got real!
970460_10201723373189039_1229511010_n.jp
fresh engine on the stand! raf raf likes this.
1150196_10201723378509172_525417506_n.jp
just need to clean up the bolt on bits, bolt the head down a new water pump and timing belt kit and im ready to put it together!
thanks dude,
still a bit left to do.. ran out of cash again lol. 87mm pistons make it an rb26.3 lmao
some more body work was done.
both sides in hifill
1095074_10201701384239329_1756891458_n.j
933931_10201701406359882_1770990297_n.jp
i used james race engines, i cant recommend those guys enough
they picked it up and dropped it off, kept me up to date, informed and explained every thing to me and made sure i understood, and really made me feel important.
the biggest wow is the quick turn around time, Hedley and Scott dont muck around one bit!
http://engineaction.com/photos/james-race-engines/.
Not much so far. Cleaned the cold side and mocked it up.
Bolted the oil pump on.
Also, if your cars never had an oil pump change. Change it. Old pumps gear was cracked! Time bomb!
Yep pretty scary considering so many cars are out there with unopened engines. Might finish cleaning the cold side tomorrow and bolt everything up :) cannnnnnotttt wait until we put it in
New pump was always on the cards for mine. 170k on it and oil pressure was shithouse . New pump fixed it. $400 for the pump ex Nissan . Labour was the killer on it though.
  • 3 weeks later...
smallish update.
cleaned up the cold side.
ever noticed that the ports look like ball sacks?
533946_10201730687611895_2075338691_n.jp
led dash lights came in
1146507_10201779571913972_648291753_n.jp
rear main, oil pump and sump sealed up and bolted down
So bit of an odd update.
Im considering stripping the car and scrapping it when I get it back.
Im over it.
I dont know why. I just am.
Il keep the motor, wheels and kit though
Im over it.
time for a vl?
Im over it.
Well that was a waste of time and money then.
So hell bent on getting a R32 GTB Replica Twin Turbo happening with full wide guards etc.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
