Just have some other things going in that are alot more important.
I havent seen the car for about 2 months.
Im going there tonight.
Sit in it. Start it etc.
See if that riles anything up.
I said the same thing the other week.
My missus punched me in the arm, called me a faghet, then told me to get my shit together and finish the darn thing.
Finish it dude, you'll be happy once its back on the road
Haha well.
After the whole world called and egged me on to finish it.
Ive decided to finish it and enjoy it.
Thanks guys <3
Went to see it today.
2 months of primer curing = rock hard primer :D
So bit of an odd update.
Im considering stripping the car and scrapping it when I get it back.
Im over it.
I dont know why. I just am.
Il keep the motor, wheels and kit though
f**k you're a phag, finish your shit flamin mongrel dream boat.
relax bro.
well, this is one of the final body updates.
after this, no more pictures. not even on facebook.
ill let the reveal do it for me :)
this is what BL0 looks like inside a factory using a PPG mix
looks alot better than the debeer crap i used the first time.
1237398_10202052491456790_1622918441_o.j
1002623_10202054145778147_1774812030_n.j
  • 4 weeks later...
well.
i have a lot to tell you guys about.
but i think it would be more fun to let it all trickle into the thread.
interiors looking a bit shabby and derelict.
1384019_10202174294221783_916356906_n.jp
no seats though...
1380845_10202176287831622_343298112_n.jp
test fitting the new guards and bonnet.
my new recaro "confettis" arrived too. they will be retrimmed.
1385961_10202183747778116_507455231_n.jp
besides all of that. as of today. the head studs have been purchased, HKS GTSS turbos, Gates timing belt and water pump kit and the body has been blocked back and ready for wet sanding.
were hoping it will be in the oven on monday afternoon :)
You can get em reupholstered, genuine Recaro fabric is like $50 a metre for the standard stuff though :S. Any decent interior joint should be able to replicate the Recaro logo.
Having the brand stitched in comes at a price.... I got my racing seat re-done in a pretty basic fabric without Sparco emblem and wasnt particularly cheap. (mind you racing seat has the wire pulling it tight and got new cushions too)
Rails havent arrived yet. Ill see tomorrow.
Doors are on and being aligned. Some gaps we cant improve on but hey. Its fibreglass. Too much filler and itll be perfect and eventually crack like a mofo so ill live with it.
Also.
Cars almost ready for paint
Turbos arrived and are in perfect nic.
George (OMGGTR) Is coming to do thr timing on the motor and bolt the head down.. its all happening gentlemen. ;)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
