On 8/2/2016 at 2:18 AM, Terry_GT-R34 said:
Has anyone been caught up in substantial price rises of late?
On what specifically? I know Nismo was supposed to raise prices across the board, at least so I heard. Not sure if its because of us Americans buying up a lot of 32's and wanting parts or what lol. But that is why I splurged a few months back to get parts at those prices before they raised them up a bit.
Anyways, found a cool shot of my car from a Street Driven St.louis drift meet. Wish I had time to give the car a deep clean! Got to love Nismo 10th anniversary recaro seats!!
Edited by JTCC
  • Like 1
Prices only went up on a handful of nismo parts, mostly the carbon parts. I have compared nearly everything in the 2015 vs 2016 catalogue.
Nismo is offering less discount to suppliers in japan so even though the retail price hasn't increased you might find the parts costing you more than they did before April 1 2016 depending on who you use to import your parts
  • Like 1
My set of the Nismo LM-GT4 Omori Factory 2016 Version 18x10.5 +15 wheels arrived yesterday too. Great minds think alike hey Raj!
Nice to have 4 sets of LM-GT4's again, i was feeling a little short dipping back down to only 3 sets there for a minute  ;)
Edited by Gts30t
  • Like 1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
