Can anyone tell me if the Nismo oil cooler has a thermostat? [mention=137648]baicai[/mention] do you have one fitted to yours? I'm wondering if there is any issue with over cooling the oil in normal driving situations.
Nismo oil cooler does not have a thermostat, no issue with over cooling, only issue is you have to warm up the car for at least 5 mins before driving.
  • Like 1
What happens if you just start it and drive it? Takes to long to come up to temperate you think?
I am not a big fan of letting cars warm up by having them sit there and idle. I also can not be stuffed with it either. If i cant just start it up and drive it then id rather buy a hks unit with the thermostat and an extra 2 rows on the oil cooler itself.
Any cooler regardless of brand that doesn't have a heat exchanger like the stock one has the potential to overcool the oil if it doesn't have a thermostat. Some people just cover the cooler in Winter. On the other hand any car can be driven away from cold (I never idle cars for any length of time if I can help it) so long as you don't cane them before they get up to optimum operating temperature. Driving them is the quickest way to achieve this.
  • Like 2
Would it be a waste to use oil cooler for a street car? I can imagine it being really useful in the track as you're doing wot most times... doh...
Yep, not required for Street use. I even have mine covered at the track unless it's a hot day.
On 09/03/2017 at 11:37 AM, Anfanee said:
Thought i had posted here but it appears not.... the Headrest on the interior has since been fixed as has the horn button been straightened haha, was a quick snap when instaling. Still restoring the foot rest.
IMG_20161125_1950473.thumb.jpg.af91a48005db5664669f7aa2184baa16.jpg1481531512845867067855.thumb.jpg.714c4564757a223cae19968ff997dbc9.jpgIMG_20161125_1949145.thumb.jpg.91fb13b939ab95afeca4db87d0e46e9b.jpg
Is that also the NISMO pedal kit? Looks like you have installed them over the top of the standard rubber pedals?  I have a set that I am yet to install and am wondering if this is the correct way.
Yep that's them, you drill into the metal for the clutch and brake pedal leave the rubber for the accelerator. Since they were not specifically designed for the 32. Alternatively you could buy a set of 34 pedals to suit.
  • Like 2
Got more pics of the nismo interior and where did you purchase them from
Where you get the nismo interior?
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
