  • Replies 280
Posted Images
I'd share a garage with you if I was entering :)
Turns out they don't take pre-bookings now, and you can only book them on the day. You need to call client services on 0418 554 734. A lady called Marnie is rostered on for this Saturday... confirm pricing with her but I believe it's $165 per garage (fits 2)
I'm told hey accept cash, eftpos, credit cards.. there is also an ATM on site.
That is so damned expensive - with bike trackdays you can fit 4 bikes in a garage and its $10 per bike, plus everyone uses tyre warmers, uses their electricity too.
Jeebus! 1:13 at sandown is decent. Still not quite as quick as that sports sedan thing that did a 1:06 :D but that's extreme-cheater-fat-slicks-tube-frame-6L-chevvy-carbon-everything spec.
Yeh I'm not sure how that works either.
It was on slicks for sure and was hella loud yes. I though he had entered WTAC, that makes sense.
Miles came second in Club Sprint @ WTAC last year - a bee's dick behind Marek. But that car is now too far out of Club Sprint regs with all the weight saving he has going on so he was going to run in Open but as I said tyres are still too much of an issue for R35's in Open/Pro so he withdrew. I'm really keen to see what the Cyber R35 does with tyres of the next few years of development because its the biggest issue facing Mark Hansen in QLD because the roll centres etc just aren't working properly running such small diameter wheels. He reckons they really need 19's as a minimum but there just isn't good tyres available in the bigger sizes.
Surely the 'embargo' on larger tyre development will cease within the next 18-24 months though....?
They have a pretty good Cafe on-site.
They do real Hamburgers, not out of the packet ones.
How many of you need membership notes by the way?
- Scott
- Dave (sorted Martin has your card)
L platers get same track time as rest so nothing to worry about there.
I'm on 98 and will be brining a full tank plus 60L if the forcast is ok, for 2L
If your vokda powered...umm lots??
Goddamn...your saying you will use over 100ltrs how much power you running..
guess I should just fill the boot then, good thing its only a buck a litre..
I'll be amazed if my car doesn't break before I got through a tank actually.
I'm going to bring 80L of ethanol, plus 3/4 of a tank, got to allow for the trip home.
Can we lobby the local United for an e85 pump? :)
Yes please, I mean the damn servo is ideally located for E85.
I'm filling up, uses about 1/2 tank to get to the Island. Bringing 4-6 jerry's (4 are filled now, if it can be assed filling the other two...not sure).
But you L platers won't use as much fuel as the rest of us.
Holy shit im bringing 40L of fuel plus half a tank. I thought that was alot. 98RON. 320kw.
You're not driving the car there though....
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
