Skyline r34 gtt (rb25det neo)
I just installed some tomei poncams type b 260 degrees 9.15mm lift and as stated by tomei no need to upgrade the valve springs.
i also installed the adj cam gears but only the exhaust side would fit, intake cam gear didnt match the intake camshaft. so i just used one old and one new
the timing is perfect and the knock is only on idle and coming from the exhaust side.
at first i thought it was the CAS but not too sure.
im running stock afm and injectors at the moment but will upgrade once the knock has gone and it hasnt been tuned yet but that shouldnt cause a knock.
any help or suggestions would be much appreciated.
https://www.sau.com.au/forums/topic/404757-tomei-poncams-type-b-engine-knock/
If its an r34 neo engine, it has solid lifters
This!!
They should be a drop in application, if you have done that and have the Ex gear set right it should be fine... Mine are sweet :)
This!!
Just for future reference, whilst they may "drop in", valve clearances should be checked and re-shimmed as required.
Yep, nissans clearances will be a better guide. and 'close enough' isn't good enough either keep in mind too much it'll slap the valve up and slam it on seat, too little and the valve wont get enough time on the seat to cool.
Actually the initial/final ramp rate has a lot to do with choosing clearances.
Having said that, going from Nissan's 0.2 - 0.25 sort of clearance to the 0.45 territory suggested by Tomei sounds like madness. You might add 0.05, not more than double.
Edited by GTSBoy
Don't trust those stickers, as part of compliance there has to be a sticker mentioning timing, clearances etc. Well mine says BTC of 15degrees (RB25), which if you know RB26's actually run a BTC of 20 degrees.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
