as some of you may know I'm doing a build on my R33 GTS25T 2 door.
currently just a bare engine in the bay atm so ive purchased many parts.
today i recieved my inlet manifold i bought off ebay.
slide industries is the company i purchased from, owned by drifter Ryan Cummings
from what I understand they get them from china and do a thorough inspection of the product.
First impressions unboxing.
Good packaging, everything covered.
overall inspection, good design, good quality, no gaps no casting out of place. inside is really clean and smooth but I highly recommend you always give a thorough clean to any cast products you plan on running.
all the galleries line up, came with all fittings. only thing missing was a throttle body gasket, got some gasket paper and sealant to do the job.
Only got a couple of pictures as I wont be instaling it until my oil filter relocation kit and oil cooler get fitted.
Rough test fit
going to need a new washer bottle, pretty sure ill use an R34 one.
Edited by Crazy Xav
more or less fitment wise, i was expecting to have to get it machine out to line up with the ports on the the head. but did some fitment tests and all lines up so should flow reasonably well.
I will definitely get the face machined as a safeguard. I dont expect any performance increase what so ever. more of a convenience thing (less piping & easier to work on)
Looks fairly simple to install also, but for reference here is what ill be going by.
http://www.skylinesaustralia.com/forums/topic/181826-how-to-greddy-style-plenum-install/page__hl__plenum
Upon removing old inlet manifold (hours and many swears later) one of the heater hoses broke, which happened to be the only non nissan hose, definitely using all nissan genuine hoses.
may paint it black if it shouts "defect me" lol.
you will find its the oposite, everything on the intake side of the engine (under the intake) is now harder to get to and work on. i have and have had the greddy intake for years, prepare to swear at the car any time you need to do something under there.
Damn! lol. i swear enough at this car as it is.
was an absolute b*#ch to remove the standard one, as the car had the cruise control module and alarm siren right next to the inlet manifold.
they have been moved (cruise removed) and oil filter relocation going on as it was already a big job gettng to the oil flter without covering everything.
Have you ever had to do a starter motor with the GReddy fitted?
Makes changing spark plugs a breeze :D did you go with the stock size throttle body, or a bigger size? From what I understand, no real performance benefit with either fhe bigger TB.. Just a more touchy throttle feel, and the ability to flow more air, with less of a pressure drop, and a drop in temp.
Going off the venturi effect anyway :D
from what ive read it can make throttle response doughy down low but improve mid-high range?
It came with a 80mm throttle body. being aftermarket there is no where for tps sensor? hopefully this wont effect much as I'll be using a wolf ecu.
Paid $700 for the kit, there is a fair few cheaper ones, but you have to source nipples and hoses.
Yeah its just a b!+ch to do! that top bolt.. so many grazes and my neighbours asking me to stop yelling lol.
Yeah ive read you loose a fair bit of mid range. Pretty annoyed i have to cut a hole under the washer bottle, as it already has a FMIC and the hole has been cut to the side. But its all a learning experience i guess.
You could try putting in a machined spacer plate between the plenum and head. Ive read of guys thinking this could counter-act some of the loss in midrange. Are you running e85?
Going from 98 to e85, personally I think the difference in midrange wont be overly felt, as the fruit juice would bring up the midrange anyway.
As for the throttle being doughy down low, there is a bit of a misconception about this.. You have to remember that with the bigger throttle body, each degree of movement compared to the stock item, is actually opening a larger area = more air for a given movement = more power due to more combustion = a very touchy throttle.
Turbo size, etc, also plays a big part.
Ive also heard of the spacer idea, as the longer runners on the standard item are what make it so balanced. not sure if ill be going E85 yet, going to be mainly street driven and tbh going from a standard tune to whatever the end result is ill be happy.
The turbo is a Hypergear ATR43. G2.5 profile. unsure of exact specs. Thankyou to everyone who suggested I get one of these turbos :D
Check the flange with a straight edge and pressure test before fitting. Buy or make an adapter and use your stock throttle body and TPS (sell the 80mm one to get a few $$ back).
I wonder if there is anyway possible to avoid cutting a new hole and reusing the hole previously cut, I am also thinking of moving to an aftermarket plenum (purely because I want to lol).
It seems there is enough room to run a 45 degree silicon pipe then straight down and back into the existing cut hole.
Does anyone have a photo?
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
