as some of you may know I'm doing a build on my R33 GTS25T 2 door.
currently just a bare engine in the bay atm so ive purchased many parts.
today i recieved my inlet manifold i bought off ebay.
slide industries is the company i purchased from, owned by drifter Ryan Cummings
from what I understand they get them from china and do a thorough inspection of the product.
First impressions unboxing.
Good packaging, everything covered.
overall inspection, good design, good quality, no gaps no casting out of place. inside is really clean and smooth but I highly recommend you always give a thorough clean to any cast products you plan on running.
all the galleries line up, came with all fittings. only thing missing was a throttle body gasket, got some gasket paper and sealant to do the job.
Only got a couple of pictures as I wont be instaling it until my oil filter relocation kit and oil cooler get fitted.
Rough test fit
going to need a new washer bottle, pretty sure ill use an R34 one.
Edited by Crazy Xav
more or less fitment wise, i was expecting to have to get it machine out to line up with the ports on the the head. but did some fitment tests and all lines up so should flow reasonably well.
I will definitely get the face machined as a safeguard. I dont expect any performance increase what so ever. more of a convenience thing (less piping & easier to work on)
Looks fairly simple to install also, but for reference here is what ill be going by.
http://www.skylinesaustralia.com/forums/topic/181826-how-to-greddy-style-plenum-install/page__hl__plenum
Upon removing old inlet manifold (hours and many swears later) one of the heater hoses broke, which happened to be the only non nissan hose, definitely using all nissan genuine hoses.
may paint it black if it shouts "defect me" lol.
you will find its the oposite, everything on the intake side of the engine (under the intake) is now harder to get to and work on. i have and have had the greddy intake for years, prepare to swear at the car any time you need to do something under there.
Damn! lol. i swear enough at this car as it is.
was an absolute b*#ch to remove the standard one, as the car had the cruise control module and alarm siren right next to the inlet manifold.
they have been moved (cruise removed) and oil filter relocation going on as it was already a big job gettng to the oil flter without covering everything.
Have you ever had to do a starter motor with the GReddy fitted?
Makes changing spark plugs a breeze :D did you go with the stock size throttle body, or a bigger size? From what I understand, no real performance benefit with either fhe bigger TB.. Just a more touchy throttle feel, and the ability to flow more air, with less of a pressure drop, and a drop in temp.
Going off the venturi effect anyway :D
from what ive read it can make throttle response doughy down low but improve mid-high range?
It came with a 80mm throttle body. being aftermarket there is no where for tps sensor? hopefully this wont effect much as I'll be using a wolf ecu.
Paid $700 for the kit, there is a fair few cheaper ones, but you have to source nipples and hoses.
Yeah its just a b!+ch to do! that top bolt.. so many grazes and my neighbours asking me to stop yelling lol.
Yeah ive read you loose a fair bit of mid range. Pretty annoyed i have to cut a hole under the washer bottle, as it already has a FMIC and the hole has been cut to the side. But its all a learning experience i guess.
You could try putting in a machined spacer plate between the plenum and head. Ive read of guys thinking this could counter-act some of the loss in midrange. Are you running e85?
Going from 98 to e85, personally I think the difference in midrange wont be overly felt, as the fruit juice would bring up the midrange anyway.
As for the throttle being doughy down low, there is a bit of a misconception about this.. You have to remember that with the bigger throttle body, each degree of movement compared to the stock item, is actually opening a larger area = more air for a given movement = more power due to more combustion = a very touchy throttle.
Turbo size, etc, also plays a big part.
Ive also heard of the spacer idea, as the longer runners on the standard item are what make it so balanced. not sure if ill be going E85 yet, going to be mainly street driven and tbh going from a standard tune to whatever the end result is ill be happy.
The turbo is a Hypergear ATR43. G2.5 profile. unsure of exact specs. Thankyou to everyone who suggested I get one of these turbos :D
Check the flange with a straight edge and pressure test before fitting. Buy or make an adapter and use your stock throttle body and TPS (sell the 80mm one to get a few $$ back).
I wonder if there is anyway possible to avoid cutting a new hole and reusing the hole previously cut, I am also thinking of moving to an aftermarket plenum (purely because I want to lol).
It seems there is enough room to run a 45 degree silicon pipe then straight down and back into the existing cut hole.
Does anyone have a photo?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
