What i want to know is if there is a big power difference inbetween the two plenums ?
From what I can understand is that for big power RB26 applications single throttle plenums are the way to go when you're running a single turbocharger setup, whilst six throttle plenums are more useful for retaining low mount / oem turbo chargers.
Hope that helps.
Edited by Ants
Hope that helps.
first ive heard of that...
people are making 900hp plus with the standard plenum and throttles! the thing with the 6 throttles is that it causes a slight disruption with air flow (turblulence) and can be hard to tune, however there are plenty of people that can tune them and do time and time again
Look mate, I acknowledge that standard RB26 plenum can be used in high horsepower RB26's. HOWEVER, Standard throttle bodies on big powered RB26 can cause difficulty when tuning the car (as you have mentioned) and research has found that single throttle setup ups for big power applications (500+kw) are better for flow and tuning.
Just have a look at all the big powered RB26's (500+kw) and you will see they do not use standard six TB's.
Also, I do not see many low mount set-ups running single throttle plenums, why?... because there is F all performance gained from that upgrade at that power level.
Edited by Ants
no need to get up on your high horse about it! clearly you are a little sensitive on the issue but im not going to get in an E fight with you when clearly you cant except either
  • 1 month later...
There has been a massive delay with my build. The workshop who is doing my build is moving from Campbellfield to Sunshine, once they are settled in my build is going to commence. In the mean while i have picked up a Nitto oil pump.
Parts that i have so far:
HKS Cam Gears
HKS Fuel Rail
HKS T51R SPL with T62R front wheel
HKS Manfiold
HKS 60mm Wastegate
Nitto 2.8 Stroker
Nitto Oil Pump
N1 Block
Mildy ported RB26 heads with bronze valve guides ready to be sent off for a massive overhaul + CnC porting.
Edited by Tyranus
  • 1 month later...
After a MASSIVE delay it has finally arrived.. my Nitto 2.8 stroker..
Because i had to wait so long for my stroker to come i took my mechanics daily for a little "test" drive. Least to say i was very impressed with the cars stock performance.
Hope that helps.
For a whizzer as big as you are planning to run, go the 90mm single throttle body plenum. It will be easier to tune. Any advantage of ITB's will be negated by such a large turbo and the delivery it will provide.
I don't buy into the 'single TB for big power, ITB's for small power' internet theory. It's been disproved in the real world time and time again. Single TB's are simpler to tune with.... and big power with an rb26 means big lag. The main advantages of ITB's are in the lower end or transient throttle- both of these areas are 'dulled' down with a large turbo.
Personally I chose to stick with ITB's, greddy plenum and twin trust td06 l2's on my rb28. I believe I achieve better throttle response, better transient response, higher intake air speed, more even air volume between cylinders and a better sound.
Cheers
Justin
Cheers
Justin
+1 on the better sound!
Small update:
Nitto oil pump is arriving this week.
Ordered these parts which should also be coming this week:
Tomei Oil Restrictor
ACL Race Bearings (Main & Conrods)
ARP Main Studs
ARP Head Studs
Nitto Full Gasket Kit
Nitto 1.5mm Head Gasket
Nitto Oil Head Drain
ATI 1000HP Balancer and Water Pulley
Thats it so far.. :)
Edited by Tyranus
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
