I'll just be over here with my shitbox that currently runs a Nistune and my new engine which will just be a Haltech because that's what my tuner uses.
Had no issues with the old plug and play in the 34, but wasn't exactly doing anything wild with it.
The I/O expander and WB1 boxes all just sat out of way underthe dash, never gave it any thought.
Come to think of it, in all the forums and groups I'm in, only SAU seems to hate Haltech, but I that might be more that I'm in all the pleb groups and not ballers ones lol
well, if your preference is to have to buy all the hardware, whether you use the features or not, Haltech have that now too: https://www.haltech.com/product/ht-195000-nexus-r5-vcu/
And they've done some smart product development lately with the new CAN dashes and button setups
But I reckon horses for courses. Almost every car doesn't use more than the basic ECU features so just use whatever your tuner prefers in your budget. I've got Link in the stagea, Haltech in the GTR, Uprev in the Titan and no ECU at all in the patrol :p, they all do what they need to.
  • Like 3
1 hour ago, BakemonoRicer said:
R32-25t, and pay mega dollars for all the software for motec for one car! Emtron has all the nasa in the one box no software add ons needed. It’s a one stop shop ECU
I thought you were a don!!! a don wouldn’t care about the money a MoTeC costs they’d just spec everything into it and hand them a blank cheque
  • Haha 1
Haltech Platinum Pro, sure it might need all these boxes but it's solid
Haltech Elite Series, no need for a bunch of boxes - also coming soon canbus keypad integration
Cars forgetting tunes? more like tuners clicking on the wrong file and uploading an empty tune.
I've tuned probably more cars than all of you guys put together have tuned, so I speak from experience.
Only excuse for forgetting tunes are the old Adaptronic Selects, I literally had to carry a laptop in the car because on the odd day it would just corrupt itself and add in random values into the crank prime field (known bug).
  • Like 2
Oh yeah, and even though people have Emtron and their tuners use Emtron, I'll be surprised if many even use the fuel modelling. Most still tune in VE because of time/customer's budget.
dropped by insight tonight the car is up and running. It literally is off it’s head, volume is akin to a MIG fighter jet It is the best sounding SR I’ve ever heard, my whole body was shaken from what sounds like a JUDD V8 w/ 320 degree cams. It’s on the dyno tomorrow Scott is going to wind it up his confidence in my physics has gained traction. It’s a special head that’s for sure, one of one
I'm quite fond of you Johnny but I just can't support haltech...shall I post the evidence of you losing your I/O mappings , of course you only spoke about that before haltech formed an alliance with you....
I have alllllllll the evidence LOL #pwned.
i think the removal of the squish pads really adds to the aggression of the sound....
i mean, we are talking soundwaves here and my soundwaves operate from a perfect hemisphere......yep, you got it, no squish pads to disrupt the exhaust gas catapulating into the manifolds. JUN really was onto something back in the 90's....
  • Haha 3
Is the head so special it will hold the bottom end together?
Hope you don’t run out of fuel
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
