What sentences does it contain, in case we missed something?
34 minutes ago, BakemonoRicer said:
The EFR speed sensor is the limit not the fuel system (its an obvious Stage 4 1000hp+ setup).
This build doesnt contain the sentence.... "let's play it safe".......
Yeah you missed the point there champ, I was complimenting the fuel system as it's far more capable than the very obvious limitation of the bottom end surviving all the EFR can throw at it. Given the stage 4 crap though I assume I have just fed the troll and been successfull baited lol good job.
My guess is either "that's really as far as we shoud push" or "f**k, we tried to warn you".
Just now, ActionDan said:
Sounds like I wasted a f**k load of money for my power goal vs spec list then...
but you want max torque, best lap times.. you didn't want to build a Maccas Carpark Stance Box and Internets Dyno bragging car though
  • Haha 2
LOL that quote will stay with me for a while "Maccas Carpark Stance Box".
I'm hoping to outdo my mates and get like, maybe a WHOLE season of like 7-8 events before it blows apart..
f**king SR20s, why didn't I K-swap lol
I once tuned a S15 slammed on the ground (stock turbo, flex conversion, Nistune, R35 AFM)
Dropped off the Emtron to Insight today
Progress is kicking along well looking like it’ll be set for the dyno next week or week after
this build honestly Is a hamburger with the lot no corners cut , just need a sponsorship from samsonas ! Lol
Stop messing about Benji, I want to see the photos of the Carillo rods and 11.5:1 JE Pistons with custom spec gudgeon pins you dropped off with the Emtron. Will give you one bonus post-Covid elbow-bump if there's any billet engine brace in sight.
  • Haha 2
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
