Details still coming in for this. I'm putting this up now as it's going to be popular.
Saturday 22nd of December
Sandown Park Raceway, Princess Hwy Entrance
http://goo.gl/maps/yDQ66
Track Day @ Sandown
Run By: WRX VIC
Who: WRX and SAU VIC only (at this stage)
Price: TBA (much cheaper than normal)
Timing: None, byo
Requirements: >=CAMS L2S, CAMS Club Membership (SAU VIC current), Helmet, Fire Ext (in date), Car in good condition
Passenger Laps: TBA, but that's the plan
This event will sell out, we are in the process of working on positions with WRX at the moment, so get your interest up in the thread below.
http://www.skylinesa...22nd-confirmed/
Trophy Presentations / Lunch
How: We will be hiring a couple of garages and putting on a spit roast / bbq / pizza lunch with soft drink.
Food: You will need a valid SAU VIC membership card. Working on a process for others who want some.
The end of year presentation will be conducted during the day, time TBA (proposed 2-3PM at this stage).
You DO NOT need to be involved in the track day to come along. You don't even need to like racing to come along. This is our end
of year break up that we would normally have at a Pub or the like. This year we have an opportunity to hold is at Sandown where
there is heaps of free parking within the venue and we get to enjoy track day goodness as well.
Beer
Annual Belgumn Beer Garden SAU and friends unwind
Occuring the same day, early evening to late.
Time: TBA
Thread: TBA
https://www.sau.com.au/forums/topic/410829-end-of-year-track-day-presentations/
  • Replies 78
If we are an SAU member can we bring bikes on the track? :3 I know the answer to this -_- would probably make me pay for a membership again though if we could. Bike VS Car ftw.
This event is a little different to all of the others.
You'll have to wait to get access to the members only area for this one.
All other track days are multi club CAMS affiliated based, some you just go to that clubs site and sign up.
It will be a CAMS event. So you will need an Level2Speed (L2S), for Phillip Island as well.
You can get one on the day, though they may not have forms there. So I would be printing them.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
