With all the massive power being made, I think it's time for a 500+kw(wheels) to see what has been tried and tested, and to compare combinations, similar to the 400kw thread.
List as much of your mods as you wish as the more info the better: engine, turbo,cams, boost etc etc
I will start:
RB26 stock block
Apexi SPL V-Max 73.7mm billet crank
Apexi SPL V-Max rods
HKS Step 3 87mm with 22mm pins
Apexi SPL V-Max 290 11.5mm cams
Apexi SPL V-Max Springs, retainers & lifters
Supertech +1mm valves
9.0:1 CR
HKS twin GT3240 + twin gates turbo kit
Trust sump (modified)
External single stage Moroso oil pump (wet)
Apexi SPL V-Max Drag intercooler (150mm)
3" dumps > single 85mm exhaust
Microtech LT12S
3 x 044's + large surge tank
6 x Bosch Indy Blues
Caltex E85
520rwkw on 22psi on a very safe tune, no cam timing, and low rev limit.
Plenty more in it with more tuning, boost, revs and cam timing, but this will do for now.
https://www.sau.com.au/forums/topic/411489-500kw-club/
RB30/25DET
NITTO/JE pistons 22mm pins
NITTO I beam rods
NITTO 1.2mm Drag headgasket
ARP Main studs
ARP Head studs
Nismo Engine mounts
9.5L ASR sump
Moroso external oil pump
ROSS Harmonic balancer with pump drive kit
Ported head
HKS 256/264 cams
Greddy Plenum
Q45 throttle body
Speedfab Exhaust manifold
Twin TIAL 36mm Wastegates
HKS T51R KAI turbo
4inch Custom turbo back exhaust
100mm Intercooler
52mm Alloy rad
SPAL 16inch thermo
2000cc ID/Bosch Injectors
SX Fuel reg
Twin entry fuel rail
2x Bosch 044 Fuel pumps
Nismo Intank Fuel pump
3L Surge tank.
E85 Fuel
Standard RB25DET gearbox
JB Single plate Full Monty clutch
Tomei Trax 2 way LSD
Supporting mods etc etc etc
547rwkw@25psi
Trapped 137mph on a practise run then blew the diff. :(
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6577905
Dave's list in black!!!
RB30/25DET
NITTO I beam rods
ARP Main studs
ARP Head studs
Nismo Engine mounts
9.5L ASR sump
Ported head
HKS 256/264 cams
Greddy Plenum
Q45 throttle body
HKS T51R KAI turbo
100mm Intercooler
52mm Alloy rad[/font][/color]
SPAL 16inch thermo
SX Fuel reg
3L Surge tank
E85 Fuel
547rwkw@25psi
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6578235
Full boost at around 6,300. Only revving it to 8,750 for now. will lift it to 10K when it is re-tuned later.
Traction? What traction? :D I have only driven it in RWD as my attesa isn't working and on stock wheels and tyres.
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6579526
Power was still increasing at 8750 and on previous tunes (with smaller turbos) power keeps rising steadily to 10K. We have found that rwhp output for HKS turbos can match the HKS rated figures of their turbos. The GT3240's are rated at 580hp each (@1.4 bar). On an RB26 in twin form, they need to be pushed hard (around 2.5 bar) to get over 1000rwhp.
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6580969
The 3240 is basically a 3540 with a cutback rear wheel, fitted into a GT30/28 rear housing (0.87).
With E85 and an RB30 I am not surprised you're making 750+hp @ 1.7bar with a large HKS single. I would love to swap to 0.73 rears or even 0.61's as the 3240's only come in 0.87
My tuna thinks that 2.5 bar is what it will need to get to 1000.
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6580977
  • 1 month later...
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Here is the vid:
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6649687
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
