So lets clear up some of the rumors......
The original Nitto 2.7L blew a head gasket at power cruise in 2010 when we were running the GT47R through a mixture of too much boost and also too much coolant temp (it copped a cainning!). We didn't time to repair it before Autosalon, so we decided to run the car on the dyno as it was. On 40+psi it made 1072hp, but had sucked in some coolant and damaged a rod. This caused a rod failure AFTER autosalon at a photoshoot under light load destroying the N1 block. The engine was removed and replaced with a standard 05U rb26 and a T04z setup as we wanted a street style setup and we had spent a lot of funds to get to that point. The stroker kit was inspected and any damaged items were replaced and since then we have sold/fitted the 2.7L into a customers car.
For the past 2 years we have been running the standard engine and with great success, using E85 and generally running around 30psi boost. I now personally tune the car (I didn't with the 2.7L engine, it was one of my staff) and switched to a HALTECH ECU. The T04Z was getting boring, so we had a play around with a few turbos (doing more R&D) and eventually we installed the Precision 7675. I wanted to see how far we could go with the standard components as 2J's are always referred to as unbreakable and I thought it was time an RB got some credit! It went into the 700's (hp) and I was having a chat with Mark @ Godzilla. I asked if he thought 800hp was possible and he kinda laughed at me. I dont mind a challenge, so I had a new goal of 800hp. We got to 805hp and this particular engine was hanging in there pretty well! We had run 30psi, then 35psi, then 40psi! it just wouldnt break! Hell we even threw a 100 shot of gas on there for a bit more response. To me it is experimenting, but on my own gear. It allowed us to play with the Haltech ECU and use many more of its features other than just timing and fuel. It runs everything including the NOS, flat shift (when we put the sequential in there), coolant pressure protection, complete engine protection (temps, pressures etc) full EGT on each cylinder and also post turbo....the list goes on.
We are the first to realise the standard engine is a timebomb (yes we are realistic!) and wanting to do something different instead of just another 2.7L (as we had already done that), we have been building a 3.2L Nitto engine over a period of time whilst using the standard engine. This engine is getting the works including sleeves, billet main caps, 4wd girdle plate and a few other little goodies. This will be combined with a new custom head (bigger and better!) and a larger precision turbo. Our goal is to build an amazing street car with 1000hp at the wheels that can be used at Powercruise events, off street drags, air strip run, 1000m races etc.
We love our 34 GTR so stay tuned for more updates as we fit the new engine and attend more events, showcasing it performance.
Trent
Trent
Damn. I liked the rumor that the rod bent BEFORE the autosalon dyno run. lol
It's sounds like you have had alot of 'fun' with this car over the past two years and i'm actually keen to see you install the 3.2 and poke it with a stick.
I look foward to seeing furture updates with this car.
Hahaha! We liked ALL of the rumours... :P
We also like the one where apparently we're using an N1 block as our 'stocker' that's currently making 845awhp!
It's all about R&D, it's been a lot of fun pushing boundaires & we're blown away with the power that we've got out of that stock 26 so far... It's a credit to Trent's tuning.
Looking very forward to popping the 3.2 in, that's for sure :)
Up until 1 month ago, it had standard sump with the oil just filled to the top line on the dipstick, as you would with any car. When we changed the diff ratios, we installed a 9L sump and again filled it to the top line of the dipstick. WE HAVE NEVER OVER FILLED THE ENGINE WITH OIL!
You could have at least wacked a set of billet pump gears in when you had the sump off you stingy bugger :)
Edited by SimonR32
anything under 6l with 800hp and the bearings would be toast a long time ago.
How? What diffrence does 800hp make? Any engine weather it be a Suzuki mighty boy or a ride on lawn mower, if it don't the right amount of oil in it, the bearings will b toast.
It doesn't matter how much power you got.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
