Also looking at getting a PAR dog engagement gearset, 1st-4th, pretty cheap. Any reccomendations?
All I'll say is - do your research. Enough info just on this forum alone to make a decision about that type of thing...
PPG Dogboxes seems to be the strongest on the market at the moment, I have great results with mine. Just remember to upgrade the stock sandwich plate with a billet item cause if that fails then everything will as well. Have done over 50+ runs, all over 800-1000awhp going through it, you wear clutches out before the gearbox I highly recommend them.
there goes that idea then! must remember, you get what you pay for -.-
man up and get an OS88 sequential! :P
but def keep us posted as to what you do because ill be heading down the same path shortly so will be interested to see which way you go
Edited by Frosty
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Nicely done. It's no easy feat to make 850hp but glad to see you finally decided to run it and put the shit talkers to rest.
I can gladly agree that you indeed make over 800hp and am very interested to see you push that stocker as far as it will let you. At this point, even if it broke, you're currently making more hp than any other stock RB26 that I know of. Well done
Not sure if you are talking about Oz, or in the world... but Manny Cruz in the States claimed ~950whp for the stock bottom end RB26 he had in his Sentra drag car back in 2005, lots of people called BS - though the car ran mid 7s at >170mph and there is no reason for him to have lied about the internals - DSport in the US also had an R33 GTR they were claiming ~800whp for a few years ago with twin RX6s on the stock motor IIRC.
Not when it weighs 1700kg
It would either need that power with 1400kg to run 150 or it would need to make 1000hp at the weight it is.
Cheers Dan...
The Powertune GTR weighs 1800kgs including driver (we thought 1700kgs too, but speaking with Chea, it was 1800). Anthony & Trent are about the same weight & both cars are in full street trim with big brakes. We'll weigh NITTO in due course! :)
Mates vl calais 1400kg plus driver, with 385rwkw ran 139mph.
Same guy now has aprox 550rwkw vl running 9.0@155 mph.
I'd be more inclined to question those figures than Powertune's - but you can't compare them straight up anyway, unless the VL also bogged, and was running 20" rims wearing low profile basic street tyres. 142mph in a full weight honest street spec GTR with a 2.6litre engine (with stock internals so probably not big rpm) is insane, anyone knocking the time or power figures really outta take stock for moment.
I just copied this from another post......
I just ran our NITTO R34 GTR at the drags on saturday at Willowbank.
Ran a 10.39@142mph on Hero 255/30R20 tyres, Tein Monoflex coilovers, OS88 gearbox, standard 05U rb26 with precision 7675 turbo making 845hp @ all four wheels.
1.77 60ft
4.69 330ft
6.9 1/8mile (107mph)
8.799 1000ft
10.39 1/4mile (142mph)
Slicks and auto vs Street tyres and manual... Thus why you can't compare times and mph
Edited by SimonR32
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
