what sized garrett is that precision comparable to, im guessing between 35r and to4z ?
im still undecided what to go for my RIPS 26/30
rob from RIPS recomends a to4z but my tuner is saying t88. im thinking the t88 will be a bit big, but both are pretty outdated. Sureley with all these new turbos out now with better designed billet wheels theres something that gonna make the same outright power but spool up quicker or spool the same but make more power. Like all these borg warner EFR turbos and new precision range look good on paper but theres not much guys running them yet that can actually compare them back to back with the garrett's.
let us know how it goes, sorry to get a bit off topic :)
Installed the Cusco rear camber and traction arms on the weekend, also put in the Kansai service solid transmission mounts. Just have to finish the cooler piping, run lines for the new fuel system and relocate the battery to the boot and I think I should be all but done, ready for a tune and then hitting up the track. Got my rear Brembo's back from the painter, look a lot better now!
Top work mate, you're pumping through this!
I have bnr34 Brembo calipers I am going to run on mine as well AND will getting them done in black...
Your rears looked to of come up mint!
What's the go with getting new Brembo decals for all 4 calipers? What kind of paint did you run on the calipers...?
I am yet to source new transmission and diff mounts...where did you get Kansai ones from? Any pics...?
Also, what battery relo kit did you run...?
Cheers
Edited by $$slowmedown
Cheers
Just ebay the decals, $6 from New Zealand. I paid a painter to do it, it's not a DIY job.
greenline.jp can get you the mounts, they look like this.
Not using a kit to relocate the battery, it's getting made up custom. Will put some pics up when it is done.
Fk, sorry, what size rotors are you running F & R?
343x32mm CSC 2 piece fronts and 300x22mm DBA 4000 rear
  • Thanks 1
nice car mate , really good aftermarket parts , that jun rail looks awsome btw,
nice PTE6262 , cant wait too see OUR dyno numbers,
im the guy wit the 62-66 ball bering too,
:) take care buddy , lemme know wen u go at DYNO ,
unfortunately here in quebec , its snow coming and my tuner his gone in china to ssee his g-f for the winter , hes coming back april3 so mid april i should have my new sheets :)
Bit of an update, drove it for the first time last weekend with the 6262 and it's much better than the T88, only did a few pulls but looks like it's getting 1 bar at 4000rpm in 3rd and 4th which should improve a bit as well after tune and boost control is fiddled with so I'm happy so far!
Got the car home and promptly started pulling it apart again :)
Precision 6262 up and running
Purchased a Full Race ETS-Pro which has digital G-sensor to replace the stock one and also a new ECU to control the whole 4wd shebang
Epoxying the ETS-Pro G-sensor
Fitting the Switches
New Catch Can
and I also ripped off the old crappy looking Carbon and stuck on some 3M stuff
Edited by SimonR32
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
