Awesome mate I'm happy too lol sooo tidy. Can I ask what the deal is with g sensor awd mods ? What are the benefits of the ecu ?
More info here http://www.full-race.com/store/r14-awd-skyline/ets-pro-center-diff-torque-split-controller-for-r32-r33-r34-skyline-gt-r-1.html
Looks great Simon! When does it hit the dyno?
Soon fingers crossed, whenever I can get Sean to do it
Nice work mate, looking good!
When you relocated the battery to the boot, did you use a kit or just a variety of off-the-shelf parts? Looks very fancy! :)
Just bought the wire, terminals and a billet bracket (that's meant to be for an evo) and made it up as I went along. Happy with the way it turned out, nice and neat :)
Ran the lines for the oil catch can today!
I will print one out next time I'm down at Allstar. I just did a quick comparo
3500
GTR = 100 Gts-t = 130 (-30)
4000
GTR = 175 Gts-t = 200 (-25)
4500
GTR = 310 Gts-t = 225 (+85)
5000
GTR = 460 Gts-t = 425 (+35)
5500
GTR = 520 Gts-t = 485 (+35)
6000
GTR = 560 Gts-t = 520 (+40)
and so on holding about an extra 40hp top end...
Not really fair because the Gts-t run started at 2000rpm while GTR ramped at 3000rpm, if all was equal I think the GTR wouldn't have given any power away at 3500-4000rpm. Plus the Green car was running a fair wack more boost.
Edited by SimonR32
  • 1 month later...
Finally got my ass into gear, purchased some Advan 050's and got down to No Limits at Barbagallo Raceway last night.
I have to say that this GTR is infinitely better to drive than my old Green Gts-t, the Gts-t felt like you were flipping a coin to see if it was going to kill you every time you hit the brakes or the accelerator. This GTR is very nice to drive even with the lack of development and set up, so much more confidence!
Had a few issues, hit boost cut 11 times on the first two laps (1.74bar) so RRob pulled the boost right back to 1.1bar for the night.
Long track was just getting a handle on the car but ended up getting fairly fast by the last session. Short track I only got 3 laps in before calling it a night but was fairly quick straight off the bat. I went to the night hoping to scrape into the 64's long track and 55's short track which I thought would be a decent result for first real outing. Ended up going 64.2 long track and a 54.4 short track so much better than planned. Was stoked with my times, now resetting my goals now and keen to get back out there again.
To give you some idea of times, I would have qualified 2nd in Street Cars and Improved production class at their last meet. Not bad for what is essentially a street car with full interior and stock motor :)
Any people who track R32 GTRs want to give me some advice on front camber?
We originally set it at 3.5deg but had to raise the front coilovers which lowered it to around 3deg. Didn't have time to have another alignment before the track day so it stayed there. I know it needs more but how much? I'm thinking of going to 4deg as the next step
Well I use 3.5 degrees. But it depends on your spring rates and sway bars. Obviously the harder they are the less camber you need. Wroo tends to like neg camber due to the corners going on for ever. You take tyre temps on the night?
How did you find the Yokies under brakes with that camber on it?
Cusco Sway bars and old Tein Flex coilovers (they are not even base adjustable) so I'm guessing they will be 8kg front and 6kg rear. Have not even bothered checking the rates. No tyre temp checks on the night, I was actually running too much pressure (34psi) and have got feathering on the tread edges because of it.
Car was great under brakes, pulled up straight, quickly and easily from the 230 odd km/hr I was doing down the back straight.
Simon whats your opinion on the ets pro controller, and what made u choose this instead of ruzic.
Cheers
Pat
To be honest I set it at around half way on auto and didn't really adjust it. The car had a bit of under-steer but that was more likely to do with needing more front camber and too high tyres pressures.
It wasn't acting like a normal 32 GTR that's for sure, no tail out and then catch the slide. Just power out of the corner, gave a lot of confidence!
Looks promising and considering the times I did with lack of track time it can't be a bad thing. I'll have more of a fiddle next time I'm at the track and report back my opinion.
EDIT: Went for it over Ruzic for lots of reasons, pre-load on transfer case, more adjustable, changes easily on the fly and digital sensor.
Edited by SimonR32
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
