Vin from The video Anyone in Syd wanna go see if it's really the same car? I always notice how quickly that bloke goes past the cluster and build plates, never lingering long enough for you to get a rally good look at the numbers.
I'm gonna go out on a limb and guess.
A metric f**kload less.
With all the driveby shootings in Sydney these days you could only hope that one day someones gonna hit the right target.
looks like its much safer to stick to a trustworthy importer and slowly search for your dream car than getting one from a dealer.. its blasphemy how these people are treating the skylines... :(
Edited by C4a0s
That MP III GTR in the video J_R32 posted has 154,874 KM.... Wonder how much it'll be once it gets here
Sinno, just curious as to how you got the actual km travelled of the Edward Lees car? i am really tempted to comment on that youtube video to warn any potential buyers. this sort of thing really grinds my gears
It's just going to take one thoroughly pissed off buyer who has acquired data from both the exporter (in Japan) and the importer (here in Australia) to take the said importer to court whilst holding a stack of anomalies.
Also included shall be a declaration of proof of odometer Kms as the car leaves the shores of Japan + proof of odometer tampering after arrival in Australia.
Such proof could very well be the painting of screws to the cluster with a dye + the pics of those said screws before and after.
Further proof could be a frequency operated hidden camera where the vid can be relayed to a receiving station. Oh dear, this is getting complicated now isn't it?
Not my cup of tea.
*Edit:- sorry I brought it up. > Might have to resort to baseball bat after all > Actually I've always loved to use a mace on a chain > Where can such an object be obtained?
From the Knight shop of course. Comes in one, two or three ball.
http://www.theknightshop.co.uk/catalog/flail-morning-star-ball-p-1991.html?osCsid=f7560e0b2e024c245e4b0bd7b41c1743
Edited by White GTS-T
They get to review all posts on that video before uploading. I've already left a couple which for some reason haven't been passed from the lying turds at Edward Lees.
Their time will come.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
