Hi all!
I'm running out of spark with my RB25DET S2.
I have fresh sparkplugs and the coilpacks seems externally undamaged.
Anyway, now I'm planning on updating the coilpacks.
There's a bunch of different kinds of aftermarket coilpacks, but are there really any difference between them except the price?
Found this relatively cheap coilpack set on ebay: http://www.ebay.co.u...=item1c27d92b13
Does anyone know how this works? Any good?
Many thanks on the replies!
-Lars
https://www.sau.com.au/forums/topic/414089-about-aftermarket-coilpacks/
What's the difference between yellow jackets and the red splitfires? Are they the same?
Splitfires are blue
Splitfires are the best
Nearly 4 years with mine and not a single hiccup.
They will all create spark, but some are more reliable then others
Edited by 89CAL
To add to this thread, I recently bought a R33 and went to replaced the spark plugs and to my disbelief, I am running 5x Yellow Jackets and 1x OEM coilpack. So off to eBay I went to try and find 1x Yellow Jacket and instead saw these coilpacks "APPARENTLY" made in Japan and only $250 delivered from Japan... I do however find it too good to be true.
They are backed witha 2 year warranty (no idea how dafuq that's going to work LOL)
Cheap
Look like Superspark Coilpacks
I'm a tad game on trying them, considering the Yellow Jacket distributor wants $100 delivered for just 1x coilpack.. what a rip off!
oh link here:
http://www.ebay.com.au/itm/Performance-Coils-SKYLINE-STAGEA-LAUREL-NEO-Rb20-Rb25-RB25det-Coilpacks-Pack-R34-/271104651182?pt=AU_Car_Parts_Accessories&hash=item3f1f18afae
Edited by johnnilicte
Seriously - just go Splitfires.
There are so many folk on here that buy everything else but splitfires to save money and have issues with at least 1 of 6.
Some have had them replaced free of charge and again at least 1 failure out of 6.
I've seen 2 reports of these Fuji coilpacks (red) misfiring on N/A skylines, 1 coilpack failing within the first couple of weeks.. i'd hate to see how badly they perform with more added stress (turbo skyline).
I bought genuine oem coils off ebay for my s2 recently for $250 delivered :)
http://www.ebay.com....1#ht_693wt_1271
I still can't wrap my head around brand new OEM coils for $250.. when they're like $100+ for each coil from most traders
They were over $1000 a set from Nissan!
I bought an ebay set and they look genuine and seem to work ok. I heard they came from a bankrupted Nissan dealer in the US though why they would have huge stocks of them I don't know. I hope they are not fake but are working so far at 20psi and 280kw. See what happens with a bit more power.
On another note a Stagea owner says his Yellowjackets broke down after 18 months!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
