Omg.. I hope you can do your best to keep it that clean!
You'll notice every little spec haha.
Still a f*cking awesome job.
Thanks Zane. Trust me, I will keep it clean.
More gear back from coating
Rear hubs cleared
Assembled
New OEM Nissan gear
Dude that is looking mint as!!!
No long now by the looks of it.
Cant wait to see it rolling.
When it does you wont be able to wipe the smile off your face.
BRAVO! I have a gun grey R32 in BC Canada and always thought about doing a major as you are! I would have to buy a second GTR for I think I might miss driving it for that long haha. Nice work man! inspiring to say the least!
Cheers bra! Not long at all mate. It has rolled.....it was glorious!
Hey mate. Nice! My brother is living in Kitimatt, BC. Where are you located>? Haha yeah but it would be worth it! You could get a lot done over the 7 or 8 months of snow...?
Thanks again
Fuel pump out, in absolute mint condition!!
Tank cleaned up
Pump in and ready to put back in
Getting throttle pedal to fit up firm, was flopping around prior
Cheers to Ants for the rear window plugs
Hey how thick is your radiator, i am after an aftermarket radiator that supports the factory fan shroud as well. did you have to cut the shroud at all to fit
thanks mate. keep up the awesome build thread :)
Had the same issue with the accelerator Peddle. (R34 race peddle set)
Plus found the length & angle of the new accelerator arm was off for my 32.
So moved the peddle onto the existing arm and firmed it up the same way.
the speed and precision of this build, damn.
thats Robbie for ya.........the man is just ruthless of dedication and had the eye of a tiger.
Well done Robbie
  • Like 1
Well done Robbie
Thanks again
Tank cleaned up
Hey buddy! Ya Kitimatt is 9 hours from Williams Lake where I am presently! moving to Vancouver BC soon so can almost drive the GTR year round! well when its not raining so ya 6 months a year still haha. Maybe I will do a ground up in a year a 2! Thinking I would enjoy it! Thanks again for sharing your labor of love! NOW GET BACK TO WORK! need more pics haha
Coming along nice where did u get that small plug from
Cheers mate. From Ants on here
53mm. Didn't have to modify anything but we did have to use some rubber spacers to raise up the radiator maybe 5mm or so, before doing this the fan was only just fowling on the shroud.
Cheers man
should be put away in a climate controlled environment....too good to drive
Ha can't do it, only live once
Nice
world best skyline build... you can use this to reference parts and help you... make a sticky
Thanks mate!
Thanks Glyn. Insane amount of planning, thousands of hours and knowing the right people!
Well done Robbie
:blush: much appreciated mate, will be good to get the two of them together, give me about 7 weeks!
Man I have got to get a ride in this sometime!
For sure! Let me know when you're in Bris
Wow what a build keep up the good work :yes:
Thanks mate, not waiting on much now!
Exhaust and drive shaft in for good
Terminated the 3in drop down that came on the Apexi catback so she is 3.5in out of front pipe to first muffler then 4in section to final muffler/cannon
Mate, seriously, stop it! Posting those piccies of your "undercarriage" are enough to make any grown man milk his baby wand till it runs dry and drops off!
Everyone is right, you shouldn't drive it! Keep this one in cotton wool then make another one that you can drive!
  • Like 2
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
