hey guys :)
i got an r34 gtr
i just bought a trial titan tryforce 3' catback titanium.
i have a venom 4'' cat and trust front pipes
since fitting it last night, sounds amazing!!!
BUT!!!!!
has an awesome drone from 2700-3100rpm.
has anybody got a titaium exhaust and had the same issue?
its just got a resonator and a cannon muffler, ive heard the idea of stuffing your spare wheel cavity with sound deadening or blankets and stuff like that to stop the drone coming into the cabin, but didnt really work LOL!!
once again it sounds great but annoys me that inbetween those rpm's especially on the freeway when your cruising at 110 and it sits on 3000. :verymad:
anybody got any suggestions :no:
https://www.sau.com.au/forums/topic/414728-titanium-exhaust-drone/
  • Replies 83
Step 1: sell the titanium exhaust and pocket HEAPS
Step 2: buy a quieter exhaust and have HEAPS of change
Please don't wreck the Ti exhaust by adding some botch job muffler onto it.. Not sure if you realised but DVS JEZ was joking. Stick welding and oxy cutting are probably the messiest way to do anything, and you probably couldn't even do it with titanium.
A decent muffler will weigh more than the entire exhaust TBH.
And of course it'll make it quiet.
If you still want "loud"-ish and less drone you need to sell the Ti system, you'll never achieve both as they always have wafer thin mufflers.
Do what GTScotT said? I had to get rid of my Ti system, couldnt afford a Mine's VX Silence Ti (for the weight) so I got a stainless system, lost 80hp because I went smaller diameter.
But, for the money I sold the Ti system for, I bought the Stainless Fujitsubo, got the Ti removed, new exhaust fitted, dyno tune and pocketted a $150.
Very interested in power/exhaust size ratio. What were you making before you lost 80hp??
How on earth would that help?
noise not only exits the end of the exhaust pipe but also resonates thru the pipe itself, exhaust wrap would act as a silencer as well as keeping up exhaust gas velocity
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
