Disregard lol
Yes it should be quite responsive Dale, i was considering upgrading to the bigger rear housing but to be honest im over spending money and i just want to drive the thing.. I think the result is going to blow the 2.6 set up out of the water
perfomance should be increased by
2.9 stroker
compression bumped to 9.1 from stock
More responsive cams
Port work with standard sized valves to maintain airspeed
Much better valve springs (ferrea Dual valve springs) old ones were slinkys
Ceramic coated entire exhaust side
Engine is ready for pick up, just waiting on exhaust pick up
haha i could have the engine in by next week... but then it could be at the mod shop for up to a month (large variable) haha
it needs a couple of small repairs done and a run in Tune. The run in tune wont take Yavuz long... Go and drive it for a day straight (Nato runs) , bring it back in for full tune hahah
  • Like 1
Meh what rubbish, throw a bit of boost into it on the dyno with some load.. Tune it
drive it around (not highway ks, you need to load the engine up)... keep the RPm reasonable
we did Pauls car in 2 days from memory *Drives with brakes on hahah
They tell me at CRD to take as long as I can to run it in but drive it normal. Not sure what boost will be on it, not much I guess ?
Did they build the engine? Usually its a safe guard for the tuner if they haven't built assembled it themselves.
The longer you run it in, the longer it lasts generally, but who is really expecting 100 000kms from a built motor.
Joey, after tune I ran the boat in at the drags, seemed to work well, LOL.
From my understanding the motor is run in within the first 20 minutes of running hence why it is so important to get some power into it asap.
Isn't it all just about getting the honing on the bore sorted to get the seal?
Yep that's about right Mark.. I've seen engines that are baby'd just pissing out oil. The. Got put on the dyno for 15 min with some load and boost and the blow by nearly stopped all together.
I believe the contributing factor these days is the precision in piston ring manufacturing.
FMW = Forged Milled Wheel in B-W speak. So billet compressor.
I've found getting a good seal in the bores can take much more than 15mins on the dyno, especially when using chrome rings. A good flogging with plenty of combustion pressures pushing the rings out, and a mineral oil helped mine immensely.
Mine was driven for 2000km - nothing over 5000rpm on highway and NZ open roads (which are not straight). Put it on the dyno gave it boost and absolutely no blow by. All in the engineering job I say.
And I am glad this thread came up I was thinking of upgrading to a single BW turbo (ditching the -5's).
Might be a good idea.
Its thread's/vids like these that get me excited for my build. Btw the car looks great. My understanding was that a 2.9 stroker would make the walls of the block too thin.. is that bs? What width piston are you using?
Edited by Tyranus
It's a 79.3 mm stroke with 86.5 or 87 mm pistons. Not sure if Joey had to go to the next size.
Using a custom 87mm piston with a heightened pin location to allow for a longer rod (off the shelf) and better rod/stroke ratio. There was a small worry about having to make clearance at the base of the bore for the extra throw but after a trial assembly it cleared easily
Its a bit under 2.9L atm, but with an 88 mm piston its damn close. I kept to the 87mm cause im trying to make it last as long as possible
an 88 has been done many times before though :)
I have a graph of 2 very similar setups, one with a BW 83/75 and one with -5's
Take a guess who smoked who haha
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
