Ok, I haven't posted for a while as I was having trouble embedding photos.
I've had some ups and downs of late.  I was nearly ready to bolt the k frame to the car when I discovered my sump adapter blocked the rear dipstick hole....
So engine out, sump off and I drilled out the bush that blocks the front dipstick hole.  I made a little adapter to lock the dipstick in as it was a bit loose.
So repeated the whole process again and finally bolted it back into the car-
I ended up getting a clutch booster delete from Garage 101.  Very nice piece of billet aluminium that brings the clutch master back a fair way-
It's still EXTREMELY close to hitting my inlet but it should be ok!  If I decide to try to engineer it I might be in trouble though (10mm rule)-
So as of today I've mounted the ECU and run the wiring into the cabin, I'm now in the process of running the wiring through the engine bay and terminating it at the sensors/connectors.
In some ways I'm so close and yet I'm still so far away from completion!
  • Like 2
Wiring-
I bought myself an el cheapo Ching Long Lie AC/DC TIG welder so I can do some stainless and alloy wleding.  I've had a bit of a practice to start to get the hang of how it works.  It's a lot harder than MIG welding but I think I'll get the hang of it after a bit (ie a shitload!) more practice.  Just getting the hang of heat control at the moment-
  • Like 2
ECU-
Now E don't CU-
"She's all factory ociffer......" cue drunken slur.
I decided to mount the ECU now and properly or it'll end up banging around on the floor for all time. Fits nicely behind the kick panel. To be honest I wasn't expecting it to!
Are you able to do me a favour and measure the length of the whole clutch master assembly? Trying to work out if it will work with my Plazmaman plenum and 30 block in a 34.
Appreciate it!
Appreciate it!
No probs Brett, I'll do it tonight and come back to you.
  • Like 1
59 minutes ago, reaper said:
I am sure it was! Really appreciate it though thank you very much.
Too easy.
Pretty much finished off wiring up the top of the engine last night-
Just MAP sensor, cam and crank triggers to do from the top then the fiddly crap under the intake manifold is next.  Fitting the wideband oxy sensors to the front pipes will be fun too....  At least now having the TIG I can weld on the bungs myself once I get a bit more practice.
  • Like 2
On 10 October 2016 at 11:38 PM, infamous_t said:
LOL looks like Danny @ 101 copied the booster delete @Sub Boy32 made for me when he installed it all those years ago.
[Cough] Ripoff [Cough]
However mine uses a different Nissan clutch master that fits better and has more room away from a large plenum like the Greddy one.
Edited by Sub Boy32
  • Like 1
Missed opportunity maybe?  You might have sold a few by now if it was a few years ago!
1 hour ago, Coullsy said:
I laughed a little harder at this than i probably should of.
love the workshop
I'm glad at least one person got something out of it!
Yeah I'm pretty fortunate to have such a good shed and a great wife that doesn't ask "Where did that come from?" or "How much did that cost?" every time she comes in the shed!
Thankfully she doesn't visit too often.....
  • Like 1
Not missed, sold about 30 of them all over the world......
http://www.gtr.co.uk/forum/154737-sub-boys-r32-gt-r-then-now-9.html
Edited by Sub Boy32
I looked everywhere for one (apart from a UK Skyline site obviously!) but could only find the one I bought. Credit goes to you for the concept then, thanks for designing it!
Haha! No dramas
On 10/14/2016 at 7:51 PM, Sub Boy32 said:
Haha! No dramas
Are you still selling them? I'm trying to fit a Plazmaman plenum and 30 bottom end into my 34 gtr and I am worried the Garage 101 setup still won't clear...
Yes I'm still selling them,
 flick me and email if you like
[email protected]
Chris.
  • Like 1
Wiring is almost finished.  Just need to wire direct power to the ECU (using the wiring harness to connect directly to the battery as opposed to patching into the car.  Just reduces the likelihood of any issues and makes chasing power issues easier too) and wire in the AEM ignition module.
Mounted the pressure reg and ethanol sensor and made up hoses to suit.  I'm also running a fuel pressure sensor as well so I can use that as a failsafe to cut power if I lose pressure for any reason-
http://DSC_7932.jpg
http://DSC_7934.jpg
http://DSC_7936.jpg
  • Like 3
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
