Haha all good, if you're keen, I can get the Walbro 525 with plug and can do 2x for $435 (excluding postage 😆) or $450 shipped.
Better quote without postage to keep @Ben C34 happy lol.
Did the modifications I needed to do today to make the PRP brace fit the block/sump.
Ended up having to grind a substantial amount off the inside of the sump to make it fit.
I already had reliefs in the block sump rail for my original block/sump adapter but still had to modify them a bit to fit the PRP spacers for the section over the front diff.
Measured up the oil pickup and tigged it up. PRP have done a brilliant job of designing that part of it. They make it very easy to fabricate to pickup tube.
The block is loaded up in the ute ready to drop off to the machinist to get the girdle machined down to the correct height for the brace.
Also removed the original accelerator pedal and cable and fit a 350Z DBW pedal.  It does bolt in but I redrilled the holes to move the pedal further to the right to space it out better.
The GT-R pedal pad fits straight on but the angles are all out of whack. I did a bit of "manipulation" to make it line up pretty good. Needs a bit more tweaking but will do the trick for now.
  • Like 2
5 minutes ago, robbo_rb180 said:
You'll be happy going to dbw, I'm planning on cutting my pedal to get it to sit nicer and trim the stopper on the back side.
How long until it's back together and running?
I hope so, I've spent the dollars so hopefully it works out! I'm just looking forward to simple idle control and how clean it will be on the cold side now.  Particularly once I tidy up all of the overly busy coolant hose side of things.
In regards to when it's running I refuse to set time frames any more, I just fu(# them up anyway so best to avoid committingto anything!
I'd love to think it'll be back together before Christmas (this year!) but we'll see what happens....  Many Christmas' have passed since I bought it so what's a few more!
  • Like 3
Hey guys, has anyone got any experience with Radium stuff?  I was all gungho and ready to get the Frenchy's fuel tank lid/pump setup but then tripped over the Radium one.  The attraction is that they have an optional in tank surge pump option.  It looks like a really nice setup.  It would only be a small capacity but should have a very consistent amount of fuel in it with it's own lift pump, fuel return and venturi setup all feeding into it.
This is the link-  http://www.radiumauto.com/Fuel-Pump-Hanger-and-FHST-Late-Nissan-P1971.aspx.  Scroll down to see the surge tank option.
Radium
http://www.radiumauto.com/Assets/ProductImages/20-0700_Assembled.jpg
Frenchy's
Nissan 200SX/S14/S15 R33/R34 Single and Twin Pump In-Tank Fuel System Kit **New**!
I guess the question is "Do I really need it?"  I'm unlikely to track the car a heap but I will a bit so is there value in the Radium setup?  It looks like it would cost much the same money as the Frenchy's setup.  I would prefer to support and Aussie company but there are obvious benefits of the Radium setup.
Anyone have any thoughts, first hand experience or opinions on this?  All are welcome but none are gospel!
The radium stuff is good but I’d go Frenchies,
I had a radium surge tank, no issues other then I had to replace the loom plug as the clip that retained it broke, but I believe the new ones use a metal fastener now.
but the Frenchies stuff would be much better for what most of us would use the cars for.
Cheers for the response.  Yeah I'll probably stick with the Frenchy's but do like the modular setup of the Radium where you can add on bits and pieces.  If I stick with the Frenchy's and I do ever track it I'll just need to make sure I have a full tank of fuel.  I'll be too scared to go again after a lap so won't use much fuel!
1 hour ago, Shoota_77 said:
Block and gridle should be back from the machinist later in the week so hopefully I can get cracking on reassembling the engine over the next few weekends.
awesome news mate
  • 3 weeks later...
Fu(# you winter!!!!
That bad boy should heat things up a bit!  At $450 I couldn't refuse. I've got a pot belly but by the time to fire it up and the heat eventually radiates through the metal you're an hour in and over shivering!  This thing it was comfy in 10 minutes and jumper off in 20!
Bought a little offcut (2400×1200) of aluminium to practice welding on....
Chopped up a few (heap) of coupons to get started with. Just need to tidy them up then get tiggin.
Having a few issues getting my girdle machined down to suit the PRP brace. I think I'm in the too hard basket at the machinists. Like everyone at the moment they're flat stick and prioritising the low hanging fruit.  I'm lofty fruit at the top of the tree me thinks....
Ah well, been busy motorbike riding plus building bunks for the kids in the caravan so not short on jobs to do...  The motivation dissipation is the biggest worry.
On 07/07/2021 at 8:05 AM, iruvyouskyrine said:
The Radium tank hat is amazing quality and price. Fitted one to a 33 GTR and it was stupidly easy.
Yeah they do look good.  I think I'll support Aussie made though and go with the Frenchy's setup.  I'll most likely decide at the last minute when I actually go to buy it!  I have a tendency of changing my mind at the last minute!
Cheers.
On 07/07/2021 at 2:43 PM, iruvyouskyrine said:
Fair enough mate, where from and how much was the 350Z pedal? About to convert my S15 to DBW and would love a bolt in solution
I have a spare 350Z pedal, PM if you want brah...
I ended up sourcing a G35 one because it's rubber, not alloy like the 350Z
$70 posted from a guy on Facebook. Very much a bolt in thing with only minor mods required.
  • Like 1
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
