Haha all good, if you're keen, I can get the Walbro 525 with plug and can do 2x for $435 (excluding postage 😆) or $450 shipped.
Better quote without postage to keep @Ben C34 happy lol.
Did the modifications I needed to do today to make the PRP brace fit the block/sump.
Ended up having to grind a substantial amount off the inside of the sump to make it fit.
I already had reliefs in the block sump rail for my original block/sump adapter but still had to modify them a bit to fit the PRP spacers for the section over the front diff.
Measured up the oil pickup and tigged it up. PRP have done a brilliant job of designing that part of it. They make it very easy to fabricate to pickup tube.
The block is loaded up in the ute ready to drop off to the machinist to get the girdle machined down to the correct height for the brace.
Also removed the original accelerator pedal and cable and fit a 350Z DBW pedal.  It does bolt in but I redrilled the holes to move the pedal further to the right to space it out better.
The GT-R pedal pad fits straight on but the angles are all out of whack. I did a bit of "manipulation" to make it line up pretty good. Needs a bit more tweaking but will do the trick for now.
  • Like 2
5 minutes ago, robbo_rb180 said:
You'll be happy going to dbw, I'm planning on cutting my pedal to get it to sit nicer and trim the stopper on the back side.
How long until it's back together and running?
I hope so, I've spent the dollars so hopefully it works out! I'm just looking forward to simple idle control and how clean it will be on the cold side now.  Particularly once I tidy up all of the overly busy coolant hose side of things.
In regards to when it's running I refuse to set time frames any more, I just fu(# them up anyway so best to avoid committingto anything!
I'd love to think it'll be back together before Christmas (this year!) but we'll see what happens....  Many Christmas' have passed since I bought it so what's a few more!
  • Like 3
Hey guys, has anyone got any experience with Radium stuff?  I was all gungho and ready to get the Frenchy's fuel tank lid/pump setup but then tripped over the Radium one.  The attraction is that they have an optional in tank surge pump option.  It looks like a really nice setup.  It would only be a small capacity but should have a very consistent amount of fuel in it with it's own lift pump, fuel return and venturi setup all feeding into it.
This is the link-  http://www.radiumauto.com/Fuel-Pump-Hanger-and-FHST-Late-Nissan-P1971.aspx.  Scroll down to see the surge tank option.
Radium
http://www.radiumauto.com/Assets/ProductImages/20-0700_Assembled.jpg
Frenchy's
Nissan 200SX/S14/S15 R33/R34 Single and Twin Pump In-Tank Fuel System Kit **New**!
I guess the question is "Do I really need it?"  I'm unlikely to track the car a heap but I will a bit so is there value in the Radium setup?  It looks like it would cost much the same money as the Frenchy's setup.  I would prefer to support and Aussie company but there are obvious benefits of the Radium setup.
Anyone have any thoughts, first hand experience or opinions on this?  All are welcome but none are gospel!
The radium stuff is good but I’d go Frenchies,
I had a radium surge tank, no issues other then I had to replace the loom plug as the clip that retained it broke, but I believe the new ones use a metal fastener now.
but the Frenchies stuff would be much better for what most of us would use the cars for.
Cheers for the response.  Yeah I'll probably stick with the Frenchy's but do like the modular setup of the Radium where you can add on bits and pieces.  If I stick with the Frenchy's and I do ever track it I'll just need to make sure I have a full tank of fuel.  I'll be too scared to go again after a lap so won't use much fuel!
1 hour ago, Shoota_77 said:
Block and gridle should be back from the machinist later in the week so hopefully I can get cracking on reassembling the engine over the next few weekends.
awesome news mate
  • 3 weeks later...
Fu(# you winter!!!!
That bad boy should heat things up a bit!  At $450 I couldn't refuse. I've got a pot belly but by the time to fire it up and the heat eventually radiates through the metal you're an hour in and over shivering!  This thing it was comfy in 10 minutes and jumper off in 20!
Bought a little offcut (2400×1200) of aluminium to practice welding on....
Chopped up a few (heap) of coupons to get started with. Just need to tidy them up then get tiggin.
Having a few issues getting my girdle machined down to suit the PRP brace. I think I'm in the too hard basket at the machinists. Like everyone at the moment they're flat stick and prioritising the low hanging fruit.  I'm lofty fruit at the top of the tree me thinks....
Ah well, been busy motorbike riding plus building bunks for the kids in the caravan so not short on jobs to do...  The motivation dissipation is the biggest worry.
On 07/07/2021 at 8:05 AM, iruvyouskyrine said:
The Radium tank hat is amazing quality and price. Fitted one to a 33 GTR and it was stupidly easy.
Yeah they do look good.  I think I'll support Aussie made though and go with the Frenchy's setup.  I'll most likely decide at the last minute when I actually go to buy it!  I have a tendency of changing my mind at the last minute!
Cheers.
On 07/07/2021 at 2:43 PM, iruvyouskyrine said:
Fair enough mate, where from and how much was the 350Z pedal? About to convert my S15 to DBW and would love a bolt in solution
I have a spare 350Z pedal, PM if you want brah...
I ended up sourcing a G35 one because it's rubber, not alloy like the 350Z
$70 posted from a guy on Facebook. Very much a bolt in thing with only minor mods required.
  • Like 1
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
