  • 4 weeks later...
Finally made a bit of time to work on the car today. Only a small job but it's something ticked off (hopefully....).  I may still have to modify it which is the disadvantage of not doing it while the motor is in the engine bay. Lots easier to work on however!
My TIG welds are a bit iffy, can tell I haven't done much welding over the last 12 months. Relatively happy with how it turned out, I just hope it works once I plonk it in the car!
20220327_182437.thumb.jpg.bb1d3627aab80b284cb658c6f2748a0b.jpg20220327_190057.thumb.jpg.d8c58ef41ed3cb9b6d30728a430bacc5.jpg
  • Like 7
Engine is off the engine stand and onto my k-frame trolley. Works a treat!  So easy to move it around the shed. Once I finish what needs to be done to the gearbox I can bolt it to the engine and finish my little trailing jack dolley that supports the end of the gearbox and helps get the angles right for reinstallation.
  • Like 2
On 29/03/2022 at 9:30 PM, Dose Pipe Sutututu said:
Sexual manifold, dat split to the seat of the gate
Yeah its purdy. Bloody New Zealanders know how to make shit (as do plenty of Aussies).  NZ plays a very big part in my motor for no deliberate reason- sump, inlet manifold,  exhaust manifold, rocker cover fittings, plus some other little bits.
Turbo oil drain fits around the engine mount which is sweet!  Was a touch worried my measurements may be off but all good.
  • Like 3
i like that turbo drain, where did you get that one mate?
The flex pipe section is from Aeroflow, the stainless is just 19mm (3/4”) stainless, 2 AN10 stainless weld on fittings welded to each end of the stainless tube, 45 degree swivel fitting onto the block adapter and then an Aeroflow bolt on fitting to the turbo plus associated AN fittings to join it all together!  So in other words it’s a handful of random bits and pieces with a bit of welding, bending and head scratching to make it all come together!
  • Like 1
I’ll be firing up the welder I like that better than the braided steel drain line. Not to mention I’m only 10an a little small for turbo drain.
Go the Kiwi's ;) that is the same style manifold i have (same company as well) and it holds boost mint :)
Sweet, good to hear!
As much as we all love to hang shit on the Kiwis I do love them! Some amazing fabricators and tradespeople over there and God do they love thrashing cars!
I've travelled to NZ itself multiple times and travelled with a few Kiwis overseas and had a ball with them. They're similar to Aussies but wierder! 😂😂
  • Like 1
yes GIF
  • Haha 2
On 06/04/2022 at 4:07 PM, Old man 32 GTR said:
Mate, that is coming up a treat, very clean.
what gearbox did you end up going with? You were looking a gearset options weren’t you?
Cheers mate. Unfortunately its a long time between treats...
Ended up sticking with the Speedtek gearset despite much (understandable) pressurenot to. Interesting to note that despite all the negativity around them, they really seem to be kicking goals at the moment. They're pumping out some fairly diverse products now.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
