Anyway........... :ermm:
I think we all got a bit carried away for a while there.
I assume that the point of this thread is just to make suggestions on "Where to get your Skyline serviced" so here are my suggestions (take them or leave them):
1. Extreme Street Performance
2. Trojan Motorsport
3. Techworkz Automotive
These are the shops that have looked after me many times in the past and in my opinion are the only workshops worth taking your pride and joy to for tuning, servicing, modifications in or around Canberra.
Done :)
  • 4 months later...
Done :)
Hey guys,
Looking to get a nistune ECU for my Stagea. Nistune because I'm budget conscious.. but I havent been able to find much info on who in Canberra has experience tuning these things. I walked into DTS today and they had no idea what I was talking about.
I've searched SAU, but was looking for some local (ACT) knowledge and/or opinion.
Thanks for that. The reason I highlighted techworkz was because they're close to my work and just convenient for me. I'd love to get my car to ESP or Trojan as they are known for working on RB's, but unfortunately unable to get there without it interfering with work.
Ill give them a call and suss it out.
Ok.. so turns out that they don't do any tuning because they don't have a dyno. They're happy to install etc, but organise tuning via ESP. *sigh*
Why would that be a problem?
Drop your car off at Techworkz for a day or so and then pick it up when it's done... They'll take it to ESP and have it tuned for you, it's a win-win situation :)
I hate this thread - there's heaps of comments in here on people's thoughts on workshops. Obviously the bad stuff can't be written.
I think we should lock it like they do in NSW when people ask these same questions. People need to call around and make up their own minds because all workshops come with good and bad stories.
send it to sydney and use it as an excuse for a day trip up there
Isn't there some discussion about having it tuned locally vs interstate? The whole air pressure at home and all that?
lol, but dont get me wrong.. love a roadtrip.
why would you pay for a contractor to add a margin to someone you can deal with direct?
Most likely will head over to ESP and get it tuned and all that by them directly. I am after convenience, but at the same time I want to save $$$ anywhere I can.
The whole reason for this is because I was just after convenience.
I hope I didn't come across like I didn't like one shop over the other, I just wanted to see what option best suited me.
  • 6 months later...
  • 1 month later...
Not this thread again! Lol.
I was wondering if there was a tyre shop around that treats cars like 'ours' with care. The reason I ask is because this particular shop in Tuggeranong, where i took my Stagea to, sped up to the hoists and smashed the front lip against the ramp. EVEN after I pointed out that it may happen! Not to mention that he sat in my car and finished the last puff of his ciggerette and threw it on the ground.
I will soon be buying new rims and will require rubber for them, and I would like to bring it to a place where I will have piece of mind knowing the rim and finish won't be damaged and my newly repaired front lip will not cop a beating. heheh!
Please feel free to PM me to avoid the inevitable debate.
  • 3 weeks later...
  • 2 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
