hi all,
before anyone says anything yes i have looked thur all oil control related topics and no i havnt seen anything that answers my questions...
i have bought a nitto oil pump and collar to run on my rb25det street driven r33
oil galleries have been widen in the block for faster return from head
my questions are...
engine builder has inform me that anything above 100psi will blow the oil filter off, or the O ring, now seeing as the nitto oil pump is rated at 120psi dual spring he sees this as a problem, i have mention removing the inner spring to bring the psi down to 75psi he said this is not good?
anyone that currently has a nitto pump on the rb25 have you left it at 120psi with no issues?
also do yous have a remote oil filter?
secondly
oil restritors
he doesnt seem to wanna fit oil restritors to the block with the nitto pump coz of noisey lifters he has said he will fit them if its what i want but if it has noisey lifters its my own fault which is true
i have spoken to andrew at nitto in regards to what oil restritors i should use and he doesnt wanna give me a answer coz if something happens he doesnt wanna be blamed.. which is fair enough
have also spoken to croydon racing he has let me know what size restritors they use on the rb25 with nitto pump
and they have nothing but great news with nitto pumps and with them been on there gtr's with over 1000hp
if anyone can clear up these issues that will be great thanks
https://www.sau.com.au/forums/topic/415543-nitto-oil-pump-oil-restritors-rb25/
To me it sounds like you are using the wrong engine builder, or someone that knows nothing about the issues RB's have in that department.
Restrictions are mandatory with a larger pump, oil filter will not blow off either.
Bit surprised a company, making a product well above spec, won't give you advise though given they would've tested the product and know the issues their product would create (on a stock motor).
ill clear a fair things up
engine builder has some insights of building rb's but hasnt used a high flow pump i believe in saying that he has done all the oil mods in the block for the oil to get down quicker.... but yeh somethings dont add up and i question why on some parts
like blowing oil filter off and not putting oil restritors in with high flow pump,
also my motor isnt stock
je pistons
nitto rods
arp head and mains
256 cams
8.5litre sump baffled, gated, extended pickup
yeah thats why i rang nitto for some advise seeing they would of trail and error the pumps, but andrew has told me that what oil size restritor is really up to the engine builder :/ but if i work out the oil restritor and a head drain it be a great setup,
rang crd which help devople the nitto pump with nitto and they have helped me out with the size oil restritor they have used, thanks for that guys
Hi Guys. Oil restrictor sizing can be a touchy topic for us to recommend on when there will always be many factors about the engine and it's usage that we don't know about.
Whilst we will always do our best to talk to those using our products and try and get an idea about their build and usage, it should typically be up to the engine builder to determine the correct type of oil restriction to the cylinder head as so many factors like usage, bearing clearances, rpm ceiling, cylinder head setup, sump setup, oil viscosity and more ultimately make this decision.
We have been talking to Michael about his setup and build to help offer as best solution as we can see fit but as we have not built the engine it is a hard call. The original Sydneykid guide is a good start but every engine is different as I'm sure you can all appreciate. What works for one will not always work for another and considering a lot of shops these days that leave engine assembley to others without discussing the actual usage of the engine, the information we need is sometimes hard to get or at least questionable.
PS: R31Nismoid - In our defence I'm not sure what other oil pump manufacturer would even reply to an email / take a phone call about these types of questions??
Nitto has been great with helping out and taking the time out to have a chat and talk about everything they possible know and to give the best advise they can without building the motor them selfs, I appreciate the help nitto has given thanks guys
There is so many factors with running a high volume pump different ways to set them up, nitto pump on gtr there is heaps of info for but for a rb25 I'm struggling to find some, so I guess it's gonna be a trail and error for this build
Forged motor
Je pistons
Nitto rods
Acl race bearings
Head studs main studs
256 cams
Crank collar
Nitto pump
9l baffled, wing, gated sump
Not sure of what clearances the engine builder is running but he said they were big clearance s
Cheers man, builder is going with block one and 1x1.5
So running the nitto pump at 120psi will be ok? Not sure if that's at full noise or cold start, nitto site just says crack off pressure
Way excessive. 65-80 psi hot is ample for your application. 120 is more than needed, will add excess oil to head, not to mention potentially damaging things, remember anything under high pressure is abrasive...
Nitto web site says you can remove the inner spring which will give a 75psi crack off pressure
Do you reckon that would be the go?
But nitto do not recommend to do it :/
hi all,
my questions are...
secondly
oil restritors
Hi i have a nitto pump in my rb25 with crank coller i removed the inner spring in the pump because i thought the extra pressure would give me oil problems I was advised to restrict the oil to the head which led to lifter and cam failure I removed the restrictor and used the standard restrictors with new hyd lifters and new cams and 5000kms later have had no problems and allways have good oil pressure i also add an extra 500mls of oil at oil changes.
Specify what size restrictor you used? Did you use to small a restrictor for the wrong application etc.
At the moment I'm wondering why it is advised to block the centre oil feed instead of the rear when upgrading pump as the forces during accelration it seems would keep oil at the back of the head. Unless I'm missing where the oil feeds in around the head
Might need to go have a look at where all the oil goes :)
How is yours going for oil pressure with the inner removed?
My engine builder has removed the inner spring and added a shim...
My restritors are block centre, 1.5mm rear I believe!! The car is just a street daily driver will see street pulls and boost here and there
So you have a nitto pump and have left the standard restritors in?
And not having any oiling problems?
I was gonna get a 9l sump made up as I was even told that in one case a guy had a nitto pump on standard sump and empty the sump in 40secs at full throttle... Was also told 6.5l wouldn't be enough :/
The oil that would run to the back of the head would be the oil thats passed the lifters/cam journals and is running back down, the pressure side of the galleries would be changed minimally with G's
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
