Washed the Pulsar and the 33 after doing a bit of garage rearrange.
Never thought a Pulsar could make a Skyline look small.
I note the 'P' plate on the fridge, is there a meaning in this? :whistling:
BTW .. nice job with the garage mate, cars give a nice mix to your approach to the world.
Edited by THE34T
You make it sound easy but I'm sure it's not.
It wasnt too bad. Hardest part was getting the new cradle in without a diff. Had to balance it on a plate with the jack under it. Took some jiggling to get the pins lined up.
Dropped my two r200s off at diff shop thismorning to get the GTR mech LSD swapped into the s14 housing.
Doing this for more power handling ?
Thats so cool how sht lines up....Jap cars are like lego cars. :yes:
I need to do something about rear traction, i gave it a little squirt and got fully sideways today... not what i want.
Especially on the road with traffic and gutters and things to smash into.
Must try a softer spring setting in the back, and my rear alignment settings might be wrong.
  • Like 1
Does buying it today count? Lolol
Yes! :yes:
My Dad Traded his '94 Navara in on a 2009 SUBARU FORESTER S3 XS Premium Today!
WELL DONE DAD!
Stoked for him. :woot:
  • Like 2
Yep, now I just need the more power bit!
I imagine a torquey 400kw and drag radials would destroy the old driveshafts. GTR rear end should be next to unbreakable. I hope.
I'm going to need an alignment too with adjustable toe and camber just whacked in to get it rolling. Craig Hall should be able to sort it out :)
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
