  • Replies 77
Cool idea for shot and comp, but personally i'd cut back the skin work. find a more realistic balance?
Terrys car
AND
hehe. Understandable. However, we were aiming for that level of doll like finish for the shoot.
Head on over to fb and see some of the other work there :)
https://www.facebook.com/danbrady.co
Nice work Pezzy! They're all pretty good :) 3 and 4 are my favs:) Keep sharing across the weeks. dribble it out, maybe work on one or two shots at a time, post for feedback, then rinse repeat? took this on my break from work, Empress Falls, Blue Mountains. 8364476808_5ee45f27ca_b.jpg
Beautiful!
BTW - is that fake sun flare/burst?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
