Aussie VIN number - done
High Mount Brake light - done.
A few other ADR items like tyre placard, fuel filler neck, unleaded only fuel sticker etc also done.
It's been a good start to the weekend so far. Godzilla is 25 years old this year. That means - Club Permit!
Finally road legal after 9 years of arriving down under.
  • Like 3
Looks great and gets better every Pic
where did you get the high mount brake light from and are you happy, is it secure enough ?
I bought one similar and the first hot day the double sided tape let go :( (POS)
Edited by Sinista32
Thanks mate.
Light is a Narva 84650BL. Came with 3M double sided tape & the LED's can be angled. Hope it isn't the same one you tried that fell off :)
Autobarn stocks them.
http://www.narva.com.au/products/browse/eye-level-brake
I tried to get a Hella 5237 multiple times from the local Repco but gave up as they didn't get back to me multiple times.
Thanks - *nervous look* It is the exact same one and they're ADR approved. I bought it from Repco.
may have been the way I applied it though I did use prepsol on the glass first. It was about 38 degrees and in the sun all day. So a 50/50 chance.
If it does fall off on a hot day Wurth make a brilliant industrial strength double sided tape. :thumbsup:
Hmmmmm. I'll see how I go with it. I'm planning to replace it with the Hella down the road anyway
Thanks for the tip. Is the Wurth double sided tape good for side skirts etc too?
Do tell :)
race tune.
Currently on my setup I'm making 350kw at 20-22psi on the -9s with 98pump fuel
This is the everyday tune that is also safe on the track as I track my car a lot now
I have been told by my tuner there is more in them but not with 98
E85 maybe this year but I do daily my car, just got a new car for daily duties this month so we shall see
There is heaps of potential in these turbos if your setup is good enough, they won't crack 400 but when you have full boost by 3800rpm who cares haha
Wow and I thought I was up at odd hours on this forum :)
Something to consider (and this has been done to death on here), the only way to truly compare is to have the cars on the same dyno, on the same day, with the same wheel/tyre combo. At the end of the day 350rwkw is awesome on -9's.
btw do you have a dyno graph of your final run?- I'm more curious about the boost curve on these turbos as I know my setup was modified to hold more boost so wanted to see what they do on the top end on different setups.
On night shift this weekend ?
Yea I know all dynos are different and tyres blah blah
Numbers don't mean much to me all I wanted was something reliable with some power
I'll find the dyno sheet and post it up
They do drop off in the top end, that's just how the turbos are
Edit
329 run
B904E5CD-A205-4487-AB5D-DFBD41AF5104-568
350 run with stuffed cat screwing the top end, will go for another run next service I think
8A48BB11-9718-4233-9092-94AC91FB0942-568
Edit
329 run
Nice. What gear - 3rd?
Ditch the cat :)
Loving this build. Keep us updated!
Thanks mate. Will do :) Still so much to do!
Went down to Apollo Bay yesterday with an old mate of mine. Covered around 500km's and she ran well all day, even through the unsealed roads we came across accidentally. Got to pretend it was a rally car for a short while. They both got a tad dusty.
1913442_10151983953867734_1189276120_o_z
Livin the dream, You didn't go down Wild Dog Road, just before the entrance to Apollo Bay did you? Love that Road.
Also, are you planning on coming on the SAU Apollo Bay Cruise in a couple of weeks?
Hah! Yes we did :)
I now understand why it's called Wild Dog Road.
Hmm possibly, man.
It's a bit rough but an awesome drive. Great views once you get to the top.
Looking forward to it. It'll be the 1st time I've taken the car down the GOR since I bought it.
Hi Shivam, I'm the guy from Perth who approached you & your mate while you were resting up in Apollo bay on Sunday.
Found your build thread you were telling me about - good work! It was nice chatting to you fellas. I'm definitely missing my car after a few months away from home as you could probly gather by the way I chewed your ears off!
Enjoy the car after all the hard work mate. You never know I may meet you again later this year if the SAU Nats are held at Phillip Island!
Wes
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
