  • 6 years later...
2 hours ago, Milhouse said:
What has happened to the price of e85 in Canberra!? It used to be cheaper than 98 and now it is almost 40c per litre dearer...!
I would say nothing happened to the price of e85 , Did the price of 98 go lower?
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7933561
On 17/06/2020 at 9:13 AM, Steve85 said:
Six and a half years. Not a bad dig up.
If you are converting your car to E85 for the fuel savings you're doing it wrong...
He he yep I did a search and this thread came up. Nope not looking for savings but just though last time I checked that was cheaper than 98 but you use allot more of it anyway but now can’t believe how much more expensive it is! But probably doesn’t have a big market in Canberra with only 2 servos selling it so got to be expected..
  • Like 1
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7934183
You did a search? No one searches... Cue: the same question over and over... :D
I must say, i'm very spoiled being in Melbourne. There's United E85 dotted around in most locations. I feel bad for the rest of the country though... :( Good thing too my range is about 150km.
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7934185
  • 4 months later...
it USED to be cheaper, but the market dropped out of it, and they realised performance peeps would still pay for it.
Now Caltex doesnt sell E flex, makes even more sense, as they have a monopoly on the market.
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7942836
It also needs to make financial sense for them to stand by it, it's a low turnover product with an expiration. If I was buying a product in bulk that was going to sit there and go off while very few people buy it, then I would be covering that risk by charging a premium for it.
I just feel there isn't much reason for anybody to complain about it, flex fuel is so easily achievable that if you're running a high performance street car on dedicated E85 then that's really nobodys problem but your own. And if you only use it for the track, then it isn't that expensive that it makes a big difference compared to tyres and track hire. Personally I'm happy to pay the going rate for it if the alternative is that it's taken off the pump and we have to go back to ordering in 200l drums from Sucrogen.
  • Like 1
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7942838
Adding ethanol to 91 reduces the price.
Thus, Ethanol is cheaper than ULP 91 fuel. by a significant margin too.
Add more than 10% of it though, and it is somehow massively more expensive.
For that reason alone they can get f**ked. I am glad I'm on 98.
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7942840
  • 1 month later...
  • 4 months later...
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
