Im just curious how many people drive a rb26 powered vehicle as a daily to and from work? What mods do u have and how much difference has it cost u in fuel?
I have a rb26 powered r31 and was looking to grab a power fc, injectors and eventually n1 turbos. At the moment im getting around 350 to 400kms driving in traffic conditions and around 550km+ hwy driving. This is with a 60l fuel tank, ball bearing r34 turbos and full exhaust with 12psi.
Im willing to compromise a bit but not only to get 200l from a tank lol as i do a fair bit of driving. Interested in what others are getting from there daily rb26's
https://www.sau.com.au/forums/topic/419914-who-uses-a-rb26-as-a-daily/
I split my daily duties between two cars but I get about that 450km/tank mark with 280KW. I actually get better fuel ecconemy in my R32 GT-R than I did in my GTS-T because the off boost drivability is a lot better. As we all know, you need to rev the nuts off an RB20 to make it move. Not that I had to do much in general driving, but I had to hit boost more often.
I've been dailying my R32 GT-R now, usually driving in traffic. Usually get 450-550 km per tank (60L) depending on how much boost it sees (not much) and more importantly how the AFMs feel lol. I got 650km once, but I did lots of highway kms and the AFMs were kind. Engine is standard, standard turbo, standard dumps and aftermarket everything after.
My goal is to get 10L/100km, which I believe is achievable with Nistune, new coilpacks and new AFMs.
You should be easily getting 550-600km to a tank if you take it easy. R31s are lighter and don't have 4WD.
When I had my R32 GTS-t, I was easily getting 600km per tank in traffic. Only mod was R34 turbo, everything else was standard including the exhaust. Damn I miss that car :( especially the sunroof lol.
Biggest factor is your right foot. If that's in check, then it'll be O2 sensors, spark, tune. Also if your car is an Aus-spec, make sure the rear calipers aren't dragging.
300KW and everything under the bonnet oversized pistons, 400Km per tank (If im lucky). It's been off the road for about a year though so im still not into the light foot stage...
I wouldn't use a 26 as a daily just because they are old. and they are cursed. I suppose the biggest difference you will see is from the turbos? if you have a turbo thats boosting in at like 2k (mine does) there isn't alot you can do about fuel.
I drive my 260rs everyday into melbourne cbd and out again all through peak hour. Quite stock atm, running 12psi, boost controller, turbo back exhaust and pod filters, SAFC.
I get 350kms in city traffic and 500km on highway driving. Being a wagon its heavier also. :-(
thats good to hear that with minor mods fuel economy still remains pretty decent. Have u all kept the standard cooling systems in place? one thing i find is the 26 feels horrible in the heat, keeps me in cruise mode though which in return keeps me out of trouble with the boys in blue so no complaints there. Only main problem i have had has been a few split coolant hoses over the past year, apart from that a 26 is a joy to drive daily
  • 6 months later...
I daily my 34 GTR. With front pipes and exhaust I was averaging 320-350kms in inner west traffic every weekday. With 275 tyres, that makes a difference too I think.
Now with e85, haltech, 1000cc inj, pump, wideband I got 110kms to half a tank. With about 50% highway 50% thrash and traffic. Not real happy with that to be honest. I'll give it a couple of weeks to suss out what the average is. I may have underfilled the first tank of e85.
Not sure - didn't dyno it prior to putting the Haltech etc in.
Didn't have anything expect the front pipes and exhaust previously - it was boosting to 1.2bar by itself in 1st and 2nd and about 0.9bar in 3rd and 4th in cold weather.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
