Hi everyone,
I think i have a blown turbo on my 03, 250 rx t . It has 95k on the clock and its stock other than a turbo back exhaust system.
This afternoon i could not start the car, a cpl of tries later it did start but something was wrong. It was running very poor and i could smell oil burning and it would deny to rev above 3000. I just wanted to get an idea of you guys before i call a mechanic in to tell me what it is and how much it would cost to fix it.
Similar posts were made by fellow stagea owners and there were some nasty numbers quoted.
So any advice will be most appreciated.
I would have expected the turbo to last more than 100k kms especially if its left stock, but oh well i think sh*t happens....
There is also another problem that i would like to mention. Recently when i brake it feels like the disks need machining but the funny thing is i do not feel it on the brake but on the gear knob instead.
one mechanic told me that it could be the front lower control arms which i purchased from Japan, then another mechanic told me that the arms were ok but the prob is from the diff mounting bush. Geting confused , took the car to another mechanic and to my surprise he said it wasnt the diff mounting bush either and he could not identify the problem.
Told me that it would be ok and not to worry too much.
But the thing is if i go a bit heavy on the accelerator, it really can be felt even when you are not the driver.
First things first, i think i need to fix the turbo in a most cost efficient way as i m in between jobs at the moment......
Thank you all kindly
Murat
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/
I can do the turbo in Sydney! Looks like the mechs are taking shots in the dark! Did you say it's only under brakes.....if so more than likely when the car arrived here it was driven off the boat with the handbrake on....that being said you should only need the rear rotors machined or replaced.
Btw by the time you finish the turbo with all parts drive in drive out its about $2k.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6770070
Got a friends' mechanic friend coming to have a look at it today just to diagnose the prob. Started the engine again this morning, it was idling sort of ok and was able to move the car a bit, but engine light was on and it was still smoky. Thanks for the input, once i make sure its the turbo, i ll pm you if you dont mind Jetwreck.
Oh and i m in Sydney now, used to be ACT....
Edited by baymanx
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6770295
The mechanic thinks its quite likely the air flow meter, not the turbo... but i really wouldnt mind a nother opinion from someone who really knows a lot about this model.
I live in westmead, i would really appreciate if you could spare some time to have a look at it, i can give you my mobile if i m in your area or close to you. But if its not on your way or close, i will just look for a replacement air flow meter which i would assume should cost a lot cheaper than a turbo..
Cheers
Murat
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6770426
i ll get a brand new afm from nissan and install it.. unfortunately i dont know how to read the error codes even tho i went thru the posts which explain it.
the smoke is dark color more like black than blue or white. But i can certainly smell some oil burning too.
i ll post the results when i get the new afm.
Cheers
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771066
I dint get an engine light from limp mode.
Or I do but my globe is out :/
I bet your globe has been disconnected. Codes were lodged on the ecu, which means they should bring up the light the next time the car is started.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771068
Cheers
I had trouble with reading the error codes too. You just need to read through the instructions and try it a couple of times: http://m35stagea.info/forum/viewtopic.php?f=6&t=11
Here's the code explanation: http://m35stagea.info/forum/viewtopic.php?f=6&t=12
Once you've had a couple of goes you'll get it. Makes it a lot easier to fix once you know whats going on.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771099
+1.
Once you've had a couple of goes; it gets easier.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771109
ok i tried this a few times and it was unsuccessfull. I am doing it exactly as the post says which i followed the link above. It is quite straight forward, when i turn the ignition on but not start it, all the lights come on including abs and airbag which go off in a cpl of secs, thats when i start pushing and releasing the accelerator which didnt work. I tried this when the ignition on when only the radio is on as well and didnt work again.
I will go to Lander Nissan to get a new afm , hopefully the mechanic is correct and i will get away with just the afm.
Thanks for all the input i really appreciate it.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771660
If you are going to Nissan, have them read the error code before you get a new AFM just to be sure that is the issue.
No way should you buy new parts without knowing the error codes first!
Regarding the code retrieval process, you may be counting your second too quickly. Get a watch with a second hand to time it correctly if unsure... also make sure you wait the 3 seconds after turning the car to ON.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771683
Ok i will try it a few more times b4 i go and get the part. I called a cpl of nissan spare parts and have been told different figures which is interesting. One said $650 plus tax for afm , and $255 for sensor only, the other said $355 plus tax.
I am sure if i only replace the sensor it should work if the problem is only the sensor right?
i have the part number as 22680N21A. Is this correct? also how much should i expect it be for? there is none on ebay at the moment. Where else can i source one in Australia if i need to?
Cheers
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771700
Rang my spare parts guy & the part number I gave him has been superseeded by 22680--6N21A (T-30 AFM). He showed list price as $314 & trade price as $262.
That makes your $255 price the right one & a pretty good deal by my stealership-o-meter. He also said there were none showing on the computer as being in the country but one/some? were due into Vic in a few weeks.
I think it's about time I made some enquiries into a bulk purchase so we can have some on hand & for a better price.
https://www.sau.com.au/forums/topic/420866-m35-blown-turbo/#findComment-6771723
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
