Iruvyouskyrines Rb25Det Neo R32
Pretty good to be honest! Had a good chat with him and he said all my work was absolutely bang on which is really reassuring to here as I have no mechanical background! Just someone who is keen to learn :)
Only issue so far is small fuel leak from the hose that runs from the tank kid to the hardline. Replaced that it's all sweet.
Every few runs he keeps getting out to tighten the straps down as it keeps walking off the dyno haha :)
  • Like 1
So keen to see your opinion of your first drive when you get it back. I would love to do this one day and just have a ridiculously quick street car that's basically always on boost. Been following this for a while, I hope all your hard work pays off for you mate.
Cheers
Brennan
Can't believe how close you guys were haha. Check that tractive effort, it's pretty much dead flat and you really feel it when you drive, it just gets up and goes as soon as you hit the loud pedal.
Cam timing is still slightly out I assume due to the 25/30 situation. Revved it to 7000 on the dyno and it just kept making power as you can see. But I requested the rev limiter be dropped back so soft cut is 6600.
I'm absolutely stoked with how it drives right now, feels so aggressive and torquey everywhere.
Will give it a while and go back and play with the cam timing and give it another 10psi and see what happens :)
  • Like 3
No target. The engine will only ever make what it wants to. I don't really care about big numbers, I just want to be able to skid 4th haha.
Speaking of that, need to source a 4.11 diff, has a 4.3 in it at the moment.
4.08 ratio is what I've put in my R32... Another option for you.
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
