I believe when mr parish sold Oran park the deal was that the track must be relocated at that time it was supposed to be Wilton but never happened so I agree something is better than nothing as Oran park was used 364 days a year I'm told.
  • 1 month later...
Bit short at the moment....I can see the track has also been inspired by Tsukuba (albeit 795 metres shorter)...but definitely too short so not sure it will really get the adrenalin rushing as probably wont hit very high speeds.
Could probs see the track being extended in the future due to people complaining about it being to short.
Any track is a good track in my mind.
And, you will surely learn more about car control at a short, tight track like Marulan than you will at a quick, open track like Phillip Island or Eastern Creek. You can go fast on those big tracks but it doesn't even really feel that fast on a wide track with big run offs.
You need to go to MDTC, and then tell me how it won't get your adrenalin going.
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
