Ok I have had my fair share of fast cars in the past.
Was thinking today what sort of power would the vq require to light up all 4s from a rolling start?
I have been in fast awd cars where you plant it and its 4 wheel light up s down the street.
https://www.sau.com.au/forums/topic/422614-what-sort-of-power-for-crab-crawls/
Rolling start? I can only do it in the wet, unless you had some really crappy tyres you would be struggling in the dry.
Mine chirps into 2nd and 3rd in the dry, but only due to the stupid line pressure the current box is running. It's surprising how much power it can put to the ground actually.
Whats your specs scotty?
I browse iff my phone so hard to navigate around here.
would depend on trans a lot, autos are a lot smoother,so its less likely to happen, manuals have a harder transition between
gears and upset tyres more, its the sudden shock that gets thems spinning in the first place, and once a tyres unloaded its
easier to keep it there
cheers
darren
c34 rs4s is 1650kg apparently
m35 should be around the same as it has a lot of alloy in it (block, rear subframe, bonnet?)
also my rs4s will do it with a big drop in the wet, i doubt an auto would do it in the dry without a huge amount of power
i went to drop off some scrap metal the other day, so i had to pass through tho weight bridge.
on exit when i unloaded the c34, it was me, my gf and bit less than half a tank of fuel and the car came in at 1720kg
So thats my factory stock rs4s no sunroofs no leather.
So if we minus, me 73kg, my gf, 45kg and whatever is left in the tank, 20l roughly
that takes the stagea to 1582kg roughly dry weight.
Still a bit heavy but ok
Mine was just under 2T on the Phillip Island track weighbridge, with two fat pricks (Aaron and myself) sitting in it, with a full tank. I have added a bit of weight with coolers and bracing, bigger brakes etc but the Bride seats are lighter than the stockies.
I just weighed Craig's old electric seats, they are 24kg each on the rails.
  • 4 weeks later...
I just can't see it happening in the dry without 500kw+, which I assume is difficult in an m35. straightforward obviously for a c34.
Mine happily wheel spins as it comes on boost in 1st, 2nd, 3rd and sometimes 4th on a hill or with a trailer on the back....as long as it is wet. In the dry it's hard to even chirp second.
My car is 1800kg with me in it - RB30, towbar etc. Can't see me spinning all four with quality 255 tyres - not prepared to dump the clutch in the dry as I would worry about breaking something before the wheels will spin!!
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
