Sorry for the complete noob question but I wanted to be sure before I ordered them and can't find an answer on the site. I have a 2003 m35 250t rs4, are these the right model numbers for the QFM A1RM brake pads:
Front: http://gslrallysport.com/au/qfm-db1232a1rm-brake-pads.html
Rear: http://gslrallysport.com/au/brakes/brake-pads/db1509a1rm-qfm-a1rm-brake-pads.html
thanks! :)
Are you tracking the car?
A1rm are a light track pad. For street go for their HPX pad, and just ask for 350z NON brembo pads. Job done. Gsl rally sport are good.
Is there any disadvantage to getting the A1RM pad if doing little to no track use (other than cost)?
They will go through your rotors quicker, and will be less effective because you won't get them hot enough to be in their optimum working range.
If you are getting pad fade with HPX then you need to take it to the track. Remsa are also ok I've heard, and gsl are moving to them.
The REMSA's are brilliant; gsl reckon they're halfway between HPX & AR1M on temp range ,but nowhere near as hard on rotors as the AR1M.
No squeaks or shudder, just dusty.
I like 'em that way.
I'll be testing out the a1rms on the 180 on Tuesday. I've got a full set of them in, they need a good bedding in which I might do on the way down to Wakefield.
Should work well on a lighter car. I did have pad fade from the hpx on the track in the stagea or whatever be got in the back. To be expected after I purposely put some hard stops into them.
Everything above about A1rm's is correct. I really need to get them off mine, lots of dust , poor feel until I get some heat into them and I hate to think what they doing to my discs. However, I was very happy with the one track day I did. ( 10 min sessions at Marulan ).
Give GSL a call and be honest about what you want from your pad. If it is just for the street, just get a street pad.
Thanks everyone. very helpful advice, steered me away from a terrible decision! Ended up going with the HPX pads all around so hopefully they are as good as you all say haha
:cheers:
The HPX is a good daily/ fast road pad; just make sure you follow the bed-in instructions closely.
People seem to go bananas when bedding them in; overheat them and they squeal like a bitch. There is no need to do tonnes of stops from 100+km/h!
I did the ones on my missus car at no more than 60km/h in back streets, and they are quiet as a mouse; with great feel. Bugger all dust too.
GSL Rallysport are great to deal with as well; they had pads & rotors to me (Blue Mountains) from QLD, IN ONE DAY!
My HPX are squeal free and good feel, but dusty as all hell...
Must be the slotted discs making them do that... :whistling:
Less than 24 hours to me 45 minutes east of Melbourne..
I have hpx they stop awesome and virtually dust free. Mine do squeal like hell but maybe I didn't actually bed them right after what dale said
Shims are most important. Anything is going to squeal without shims. If they aren't installed properly, even in the slightest, you'll get squeal.
Every QFM pads have bedding in instructions in the packet.
Yeah I have learnt the hard way before.<br /><br />The advice I got from gsl was anti squeal paste between pad and shim - but not between shim and piston.<br /><br />Do you agree? <br />
It can't hurt.
I've used the stuff before, and had squeal, not used it and had no squeal. When you have the pads out, give them a small scrub on a concrete surface to take off the sheen. Helps them bed in a bit more.
Well i have put it between pad and shim, and on the other side of the shim also. I understand it just to be an insulating barrier, it doesn't stick or hold anything together. <br /><br />Will bleed them up and start the bed in process as per instructions. If they squeal I will be pissed. Ok on a tough stripped out racer or street car with one thing in mind , but on a luxury gt like a 350GT - ain't nobody got time fo dat!!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
