BlackT - re: racechrono - i used to have that on a nokia phone years ago, and its worked well with an external bluetooth GPS. Let me know if you need to borrow the GPS, its a 5khz unit that was recommended by the racechrono guys back then.
Thanks Adam, will see how it goes with the internal gps for a few laps, I have a brand new sgs4 so hopefully it gets a good signal/has a good antennae
lol
tops day
no exploding cars
... I got pretty close! After the second session out I realised the radiator was cracked. Somehow the car still took a flogging and made it home :)
Tops day mate and thank for organising it.
Cheers guys for organising a great day.
Nice pic Jenna,,,picking on an old defenceless man,,,shame on you.
Anytime Neil ;)
Was indeed an awesome day and good to see all the familiar faces. The Gtr did well, survived the whole day with two drivers.
Went to get it off the trailer this morning though and it wouldn't start. Seems like the fuel pump has shat itself!!
Jenna
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
