I'm growing a beard. Itchy as fuark atm. Any advices on how to stop this infernal scratchyness?
Shampoo/Conditioner every day and after a couple weeks it'll die down
I lasted about 6-7 weeks or so before i chopped it, not cause it was itchy, but it felt weird trying to sleep on a bed of pubes
Shave it...
seems to be working. cheers
my shaving kit ;
Omega shaving cream
Omega brush
Woodys post shave rescue
Pinaud-clubman aftershave
Alum block (almost never used).
Razor -- Mach 3 . Best disposable on the market closest to a good safety. The fusion and others simply aren't as good. Gillette made a commercial mistake making them as good as they are. Blades position and design mean they take longer to dull. They poured huge money into trying to get users off the Mach 3 but, failed ha ha..
You can get aftermarket handles for them Mekur makes some nice ones.
For afternoon / evening tidy up (if needed for event) or traveling I use a Braun top end 7 series.
Edited by rev210
  • 4 weeks later...
After a few months now of DE shaving I feel pretty comfortable with it. After trailing different brands of blades I have settled on using Feather Blades.
I also changed to a G&F Timor razor in Gun Metal only because I had noticed a very slight bend in the post of my current cheap Weishi, resulting in the blade not being even on either side of the razor.
The Weishi or the copy they sell at Shaver Shop is a good razor to learn on. Super mild angle, so hard to cut yourself. It's also hard to get a close shave until you get the angle right. Reward is there for getting the angle but, it takes practice. Very good for people who are sensitive skin types.
I've just gone back to the safety last week. Pinaud aftershave burns like napalm after a very close shave, I had forgotten about that ha ha....
I am really struggling to get a good shave at the moment. Not sure what the issue is but cutting myself more then I did a few weeks ago. Only thing that has changed has been moved houses (also new blade).
I think it is something to do with heat, my shaving cream doesnt seem to get as good a lather up in the new bathroom. Also by the time I finish shaving my actual face, the cream on my neck almost looks patchy and not even. If that makes any sense.
Could be different water or soap you use on your face (if you do). I find that depending where I am, water can be very drying compared to the tap water at my house.
Do you use shaving oil (king of shaves etc) before applying cream? Will soften/moisturise things up a bit. Also try applying cream to one major area at a time rather than whole face. Particularly with gel creams that you have to lather, they tend to dry out quickly / go patchy on you. And keep wetting that razor every few strokes, with super hot water!
I've also found the shaving creams lather better with dry hands, but they go patchier quicker this way. Less lather with wet hands, but it also makes the lather more slippery because that's what shaving cream is supposed to do.
Buy the Feather double edge razor (on eBay for $20 or from Shaveshed for $30). It comes with 2 feather blades and is sensational. As above its angled for a mild shave so hard to cut yourself yet it's quite sharp.
I can now shave with that the same way I did with a Mach 3!! But it is a million times sharper! It makes shaving so easy. Much better than the merkur hd cause its long handle.
I can not recommend this enough, it is that good!!!!
As you know the amount of water used makes or breaks the lather. Get a badger brush and decent shave cream and lather on your face. Takes a few goes to work out how much water to leave on the brush to get a good lather. Start with less and then drop more on as you need it.
I just use Nivea shave gel LOL, it's too easy and I'm still fascinated at how the smallest bit of gel expands so quickly into foam. Makes shaving time fun!!!
/tooyoungforfacialhair
Can you link me to either of these? Seems to be a ton on eBay and worried about buying copies cause it all looks so cheap lol
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
