Very nice build, personally a big fan of the calsonic r32, about ur g sensor issue, has anyone tried the do luck tarzan g-box? Apparently it claims to have fast response for the attesa
From what I've heard the digital g boxes do process a lot quicker than the OG box, but if your attessa system isn't very healthy it won't make much of a difference. Still the tarzan g box will probably be one of my next purchases so once it's installed I will report back.
Anyone going to Circuit Club on Monday?
Just bought these off an SAU'er!
Once the wheels arrive from Japan we'll be in business.
In the meantime I've been hunting down supersprints and weekend track days I can attend. SSCC and the CAMS NSW website seem to have most of them, are there any other clubs out there that run sprints?
I mentioned earlier about my unloading rear diff and this is still an issue.
What's the best setup for diff's in an R32 GTR? Currently running standard diffs in front and rear, and I'm not really sure what warrants attention first.
Because everyone that has one raves on about them, I now know why.
$1,400 or so. I got mine from the UK but you can get them locally aswell.
You don't know it's there until you put your foot down around a corner. No clunking, banging, chirping, just balls out grip when you want it. The stock diffs suck and it's not until you start playing around with them you realise.
What sort of difference in performance are we talking between shimming and a 1.5way? What 1.5way would you recommend?
What about a quaife in the rear?
Don't have any issues with spending money on good shit, but I am still on a budget and if I can get away with cheaper options where the difference in performance is minimal that's the route I'll be taking. I was under the impression shimming a rear diff in a GTR was good enough, so I'm interested to hear the differences
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
