Very nice build, personally a big fan of the calsonic r32, about ur g sensor issue, has anyone tried the do luck tarzan g-box? Apparently it claims to have fast response for the attesa
From what I've heard the digital g boxes do process a lot quicker than the OG box, but if your attessa system isn't very healthy it won't make much of a difference. Still the tarzan g box will probably be one of my next purchases so once it's installed I will report back.
Anyone going to Circuit Club on Monday?
Just bought these off an SAU'er!
Once the wheels arrive from Japan we'll be in business.
In the meantime I've been hunting down supersprints and weekend track days I can attend. SSCC and the CAMS NSW website seem to have most of them, are there any other clubs out there that run sprints?
I mentioned earlier about my unloading rear diff and this is still an issue.
What's the best setup for diff's in an R32 GTR? Currently running standard diffs in front and rear, and I'm not really sure what warrants attention first.
Because everyone that has one raves on about them, I now know why.
$1,400 or so. I got mine from the UK but you can get them locally aswell.
You don't know it's there until you put your foot down around a corner. No clunking, banging, chirping, just balls out grip when you want it. The stock diffs suck and it's not until you start playing around with them you realise.
What sort of difference in performance are we talking between shimming and a 1.5way? What 1.5way would you recommend?
What about a quaife in the rear?
Don't have any issues with spending money on good shit, but I am still on a budget and if I can get away with cheaper options where the difference in performance is minimal that's the route I'll be taking. I was under the impression shimming a rear diff in a GTR was good enough, so I'm interested to hear the differences
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
