Why not split the difference guys?
Stop all the arguing :)
But seriously, why isnt this best of both worlds?
I've seen one in real life, and it looked the goods. no welding of anything (except itself) and bam, theres your wastegate hole!
^ This. :P
Those adapters do not provide a good flowing wastegate path, but they should work fine at controlling manifold pressures.
A well designed wastegate path adds much more than good boost control, I know this from experience... Just sayn...
^ This. :P
totally agree, flow always takes the path of least resistance.. and fuark Scotty's gate job (that nearly sounds sexual) works a treat, I can set my boost to anything and I will only get a fluctuation of 0.02 bar at times from start to redline.
i thought that was true of water pressure but not air pressure.
ever seen a dim sim manifold with the wastegate flange on the opposite side of the collector? uncontrollable boost spikes :)
fair enough, i suppose if my tiny little brain is trying to understand it...the pressure builds from the closest point to where the flow stops? would that be a way to think about it?
Ahh, the flow never stops, it just forces it through the turbo if the wastegate is closed, or the gate can't flow enough.
Imagine a spray gun, force air over a tube opening at 90 degrees and it will suck the paint up into the airflow, the opposite you would expect. Same thing would happen in a poorly designed manifold if there was no pressure helping, the gate would almost flow backwards.
Water flow is always incompressible flow.
Gas flow can be either in the incompressible regime or it can be in the compressible regime depending on how fast it is going. If we use the example of air at room conditions, then the speed of sound is about 340 m/s. If you are at fairly low speeds (so, let's say about half that or ~170m/s or less) then you are in the incompressible flow regime and gas flow will generally behave EXACTLY like water. If you are at high speeds, like 60% of sonic velocity or more, then you are getting up into the compressible regime and gas flow will start to behave differently to water. It is actually a gradual change from one regime to the other.
Hot exhaust gas will have a completely different sonic velocity (no, I'm not going to calculate it for you) and therefore the velocity at which the regimes change will be different.
Regardless of the discussion of the difference in compressible and incompressible flow, when gas is flowing fast in a certain direction along a duct it has momentum in that direction. If you want it to make a 90° turn out through a hole in the side of that duct you have to give a convincing reason to do so. The only one available is a very large pressure drop (ie the pressure in the duct must be much higher than on the other side of the hole in the duct wall). The only way to do that is to have a very free flowing flow path out the hole. Almost no external wastegate meets that criteria even if it is a screamer, because the wastegate itself is a valve which is an obstruction in the flow. There will always be a certain amount of backpressure across the gate. And if the wastegate is plumbed back in, then there is even less pressure drop available because now the outlet end is at dump pipe pressure (which is a bit higher than atmospheric).
They woudn't fit on some nissans though would they ben?, i looked at them for stageas, but with a .070 comp cover they would hit the
chassis rail with one of those fitted?
cheers
darren
The one I saw was in a 32 I think. It wasnt a parralel spacer, it rotated the exhaust housing a fair bit, so it didnt just space it also the way into the strut tower. I cant remember the turbo but it was decent, around 350rwkw
I think garage7 made or supplied it.
Memory is very dodgy lately though!
Edited by superben
Has anybody ever tried this?
Seems like a good idea however you'd have to get new oil and coolant lines because they won't read the turbo...
I've changed my thoughts towards the housing rather than manifold because its easier to work with . Like GTScott I think it's about getting the gas to change direction once it's moving beyond a certain velocity .
It seems people hate theorising but anyway I believe it's a case of velocity pressure vs static pressure and velocity pressure wins .
As seen it's possible to fab a fair sized (diameter) tube/hole in the top of a turbine housing and having a large area means an easy vent path .
I think from an engineering point of view it may work better on the manifold because of the velocity trough the top of its twin ports at the collector but more difficult to do (mani off etc) and the manifold IMO is less of a consumable than a turbine housing .
I recently saw a pic of a compact (height/diameter) ext gate low down on on a turbine housing and it wasn't nearly as obvious as having it on top of the manifold or on an elbow off the same point . Just more stealth .
that's horrible for flow, why not just weld a gate flange off the rear housing?
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
