Ah just say this model skyline was the Bathurst "SPECIAL RACE ADDITION" and it was released with a top mount turbo officer. Get a little tag made up saying genuine Nissan on the turbo and manifold somewhere and bobs your uncle. Lol maybe. ;)
Ah just say this model skyline was the Bathurst "SPECIAL RACE ADDITION" and it was released with a top mount turbo officer. Get a little tag made up saying genuine Nissan on the turbo and manifold somewhere and bobs our uncle. Lol maybe.
Edited by WMDC35
And seriously what can they say to that? Nothing I would have thought. How can they prove it's not?
They don't need to. They just send you for an emissions test/what ever else the hell they want you to do.
If your on jungle juice would you pass with a 400 cell cat in place? And if you go through the hassle once and show following offices your EPA emissions test has past certificate perhaps one would be ok? Added things if your not getting up it and driving hard around town you should be right. I also love screamers myself but on the street having it plumbed in is the go for noise level reduction. But what ever you do they'll do one better at times. Other thing would be have a tune in your ecu to switch maps to a EPA safe tune perhaps? I dunno lol just trying to hope when I put my new top mount kit on I wont put off the road. Oh well I'm leaning towards a hta gt3582r at the moment with a twin scroll ass on it. Unless stao can make me something close to it's performance.
Edited by Joshbigt62r
could be stupid question....
would there be a twin low-mount option for an RB26 with these HTA turbos?
I dont think its a stupid question... It was asked a page back i think and its not an off the shelf option as far as i know!
There is an option, I'm just not certain how good it would be - Owen Developments in the UK do a few custom FP based combos which FP themselves don't release to address customer requirements in the UK: http://www.owendevelopments.co.uk/article/76/NEW_Skyline_R33-34_twin_GT2668_HTA_turbos/
They've also sold HTA4094R turbos and if I remember a couple of other interesting HTA based units which I am fascinated that FP themselves don't market.
Nice find...
As always :yes:
wonder if there are any results floating around at gtr.co.uk - will have to have a dig
1100 pounds though... each. yikes. less 20% but still...
in the old money... would these be classified as bigger than 2530/-5's?
There is a guy (mentioned this stuff recently in this thread) on the UK forums that installed a pair on his and from memory it had no surge issues or anything, but his engine failed before he managed to get a full tune into it :( If the compressor doesn't choke on the turbine or smaller compressor cover (not convinced it won't) then I'd peg it to be capable of outflowing -10s and spool somewhere between the -5s and -10s. Hard to say though
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
