Forced Performance Hta Turbos
Ah just say this model skyline was the Bathurst "SPECIAL RACE ADDITION" and it was released with a top mount turbo officer. Get a little tag made up saying genuine Nissan on the turbo and manifold somewhere and bobs your uncle. Lol maybe. ;)
Ah just say this model skyline was the Bathurst "SPECIAL RACE ADDITION" and it was released with a top mount turbo officer. Get a little tag made up saying genuine Nissan on the turbo and manifold somewhere and bobs our uncle. Lol maybe.
Edited by WMDC35
And seriously what can they say to that? Nothing I would have thought. How can they prove it's not?
They don't need to. They just send you for an emissions test/what ever else the hell they want you to do.
If your on jungle juice would you pass with a 400 cell cat in place? And if you go through the hassle once and show following offices your EPA emissions test has past certificate perhaps one would be ok? Added things if your not getting up it and driving hard around town you should be right. I also love screamers myself but on the street having it plumbed in is the go for noise level reduction. But what ever you do they'll do one better at times. Other thing would be have a tune in your ecu to switch maps to a EPA safe tune perhaps? I dunno lol just trying to hope when I put my new top mount kit on I wont put off the road. Oh well I'm leaning towards a hta gt3582r at the moment with a twin scroll ass on it. Unless stao can make me something close to it's performance.
Edited by Joshbigt62r
could be stupid question....
would there be a twin low-mount option for an RB26 with these HTA turbos?
I dont think its a stupid question... It was asked a page back i think and its not an off the shelf option as far as i know!
There is an option, I'm just not certain how good it would be - Owen Developments in the UK do a few custom FP based combos which FP themselves don't release to address customer requirements in the UK: http://www.owendevelopments.co.uk/article/76/NEW_Skyline_R33-34_twin_GT2668_HTA_turbos/
They've also sold HTA4094R turbos and if I remember a couple of other interesting HTA based units which I am fascinated that FP themselves don't market.
Nice find...
As always :yes:
wonder if there are any results floating around at gtr.co.uk - will have to have a dig
1100 pounds though... each. yikes. less 20% but still...
in the old money... would these be classified as bigger than 2530/-5's?
There is a guy (mentioned this stuff recently in this thread) on the UK forums that installed a pair on his and from memory it had no surge issues or anything, but his engine failed before he managed to get a full tune into it :( If the compressor doesn't choke on the turbine or smaller compressor cover (not convinced it won't) then I'd peg it to be capable of outflowing -10s and spool somewhere between the -5s and -10s. Hard to say though
    • Blitz ER34 at some point hopefully, should be allowed in Gr3 if they do.
    • Stock R33 boost control, with the exhaust, and FMIC done, will boost creep. There is no tuning around it if it is the factory boost solenoid.   If it has an aftermarket electronic boost controller, the settings/mapping can be altered in it.   Oil could be anything as mentioned, however did it ever do it before you did the turbo swap? How much and how often did you drive the car before the swap?   I'm hinging on too much oil supply, or it's not draining properly.   To check, pull the air outlet off the turbo. Is it full of oil? Drop the exhaust at the turbo, does it appears to be oiled/coked? Now pull turbo and check the exhaust manifold, does it appears oiled and coked the same way?   Secondly, the PCV could even be stuffed / not functioning properly and will cause blowing of blue smoke.
    • Almost any ECU would work, from a 30 yr old PowerFC to a new Motec/Autronic. But presumably you want new middle of the road ECU, meaning that you want a Haltech or a Link, most likely. As to which model though? I dunno. I don't keep track of what they have in their current ranges. You don't want a plug in though, because plug ins can start to cause you the same wiring issues that you have to chase up with your stock ECU/loom swaps when an engine transplant is involved. If you use a Haltech (and presumably a Link) you could put the base map for the engine in and drive it around and not even need to "tune" it. It will work just fine. I can't recommend a tuner without a location (and even then I can't recommend many, being as I never use any tuners except myself and my brother-in-law). And not many tuners are happy to remote tune. Maybe they'd be happier doing it for a basically stock setup that just needs to be demonstrated to be working properly. But even then, not being able to be with the car to see what the hell is going on and sort out the inevitable problems that will result from an engine conversion done by an amateur..... unlikely to be enthusiastic about the job. And if you think that just adding 2 wires for the boost sensor is difficult - you don't want to be trying to install and set up an aftermarket ECU. You're going to have to bite down hard on something with either approach.
    • wired everything up and confirmed that the red with white stripe is indeed the fuel pump pin on this harness.
