Haha and im just a sales man.
Engineer sounds lenient. Im doing a rwd rb26 swap in my sedan and will need it engineered
Iv actually emailed this same engineer before I saw any of this a few days ago now for my r31 with an rb25 in it. He's in braeside somewhere I believe. Will see what he says soon hopefully, I'm in the same boat as you.
Started on the radiator it's a HQ ebay radiator with a fan shroud I made to suit twin 12" spal fans and I moved the bottom outlet.
There's about 6mm between the power steering pulley and the fan.
Also mounted the 45mm turbosmart hyper-gate and tacked up the dump pipe. I'll finish the dump pipe when I get the flex
coupling that will be cut in the 2" tube after the wastegate.
Welded up the intercooler and piping and also fitted the synapse diverter valve which will be plumbed back to the air box.
Also started the chassis strengthening using 89x89x3.5 rhs shaped to suit the floor pan.
That poor Torana! Will be interesting to see what it weighs with all the Nissan gear in it - I'm betting it will be less than the R32. Can't wait to see the final product - great project turbo76lx!
wow, your fabrication skills are sensational!
No doubt you know your stuff!
Given your torana is 25+ years old, why not go club plates which will give you 90 days road use a year?
You obviosuly know what your doing and are bouncing your approach off engineer before application, club reg would allow you to bypass expensive engineering approvals and get you legal road use for under $200 a year.
I love old Torana's and Skylines so what's not to like here. So this will definitely be interesting once complete, to see how it handles. It ought to be a farking hoot to drive whether it handles like a Skyline or not, but I wouldn't be surprised if you find it holds the road in corners pretty good, with a nice drift every now and then when you want it. I wish I had your skills to bring back cars from the dead. I see plenty here in tas that need love and attention, but they just sit there rusting away.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
